RS232 command - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: Questions on Using Comfort (https://www.comfortforums.com/forum-159.html) +--- Thread: RS232 command (/thread-1362.html) |
- juwi_uk - 02-19-2009 Hi, UCM response for SM command is SMmmSSid \"id is the id of the message.....\" Is there a way I can find the list of message id\'s; is it in one of the config files anywhere? I\'ve had a quick look but can\'t find. For example when I login I get \"SM000111\" reply from UCM and want to decode message \"11\" (as I dont have UCM Audio to PC). J - admin - 02-19-2009 Our apologies for the slow response. We were not able to access to the forum the whole day until now. I suspect some (Singapore) government agency thought this was a subversive or pornographic website. The meaning of ID in this message is the device to which the SM message is addressed The ID of UCM #1 is 11 hexadecimal, or 17 decimal When you login on the UCM you get the message \"SM000111\" because Comfort is instructing the UCM to turn on its speaker and off its microphone. This is for the UCM/Audio but it has no effect if you have no Audio on the UCM - juwi_uk - 02-19-2009 Thanks for the response. I understand now. Could you perhaps update the docs so it says \"ID of the UCM..\" rather than \"ID of the Message...\" J |
