Pull up Resistore - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: Questions on Using Comfort (https://www.comfortforums.com/forum-159.html) +--- Thread: Pull up Resistore (/thread-1257.html) |
- engmoabel - 12-14-2008 In the siren(jp9) ,why we put a 1K-ohm pull up resistor? NOTE: This question in Comfort 2 Installation Manual . - admin - 12-14-2008 The pullup resistor is recommended to be connected as some sirens make a low sound when not activated due to a low voltage supplied to the siren It may not always be needed but it will not do any harm |
