Flash UCM05 with ZWave UCM - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Third Party (interfacing to Comfort) (https://www.comfortforums.com/forum-5.html) +--- Forum: Zwave (https://www.comfortforums.com/forum-62.html) +--- Thread: Flash UCM05 with ZWave UCM (/thread-1240.html) |
- palmlodge - 11-25-2008 The z-wave UCM has the firmware flash pins - but no serial connection. Given what Cytech normally do with UCM\'s, you\'d think the flash pins wouldnt be there if not possible. I would also have to remove the daughterboard, and place a ethernet module there so it could act as the source to flash a UCM05 ? Or is the flash pins there so the zwave can be flashed by a UCM05, but not the other way around ? Possible ? - admin - 11-25-2008 The Zwave programming pins are there to be flashed by UCM05, it is not able to do the flashing even if you plug in the Ethernet module as the communications firmware on the serial interface side is different from the UCM05 or ethernet, it talks to Zwave instead |
