Power Fail Dialout - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: Questions on Using Comfort (https://www.comfortforums.com/forum-159.html) +--- Thread: Power Fail Dialout (/thread-1171.html) |
- homelectrix - 09-17-2008 My system dials out on power failure even when it is not armed. Should this normally occur? Can I set it so that power fail dialout only happens when it is armed? Thanks Rob - slychiu - 09-17-2008 The dial out behaviour for each alarm is determined by Comfigurator in Security Types > Alarm Types > Power Failure see attached To prfevent dial out except when the system is armed, program the following in the Alarm Response If SecurityMode = SecurityOff Then Limit DialOut End If This prevents dial out if Security is off |
