Labeling Zones - Printable Version
+--- Thread: Labeling Zones (/thread-1150.html)
- Warby - 08-26-2008
Is there a way to open the details box using the keyboard?
When assign zones i tend to use the keyboard to TAB my way thru the feilds(zone name, type etc) and then enter to confirm. i then press down for the next zone but then have to use the mouse to open the box and place the cursor in the first line. why couldnt hitting enter on a zone open the box and highlight the zone name feild.
- slychiu - 08-26-2008
I presume you are using Comfigurator 2
Check out the beta version 2.9.4 new generation Comfigurator, see forum at http://www.comfortforums.com/forum20/1088.html
It does work in somewhat the way you suggested, ie you can use tabs to go to the next field. Then highlight the next zone and use tabs again to move from field to field
