Using a Meteor CID with Comfort - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Problems & Troubleshooting (https://www.comfortforums.com/forum-36.html) +--- Thread: Using a Meteor CID with Comfort (/thread-1055.html) |
- nigelgiddings - 05-12-2008 I have recently connected the Tel IN and Tel OUT connections of my Comfort system in line with the outside line. I also have a Meteor CID device which I use in conjunction with the xAPTel application which has worked very well up until now. It now looks as if I connect the Meteor on the Tel IN side of the connection it does not work properly, If I connect it on the Tel OUT side it seems OK. See below: Line -- ADSL Filter -- Meteor -- Tel IN Tel OUT -- PBX (Meteor does not work) Line -- ADSL Filter -- Tel IN Tel OUT -- Meteor -- PBX (Meteor does Work) NB the Meteor is not strictly \'in-line\' it is \'T-ed\' accross the line at the point shown. While the Meteor would capture all incoming calls irespective of position I was hoping to monitor outgoing calls made by Comfort (The Meteor monitors both i/c and o/g calls). I wonder if there is anything between the Tel IN and Tel OUT connections that might interfere with the device? Has anyone else experienced similar? TIA Nigel - admin - 05-13-2008 Not familiar with Meteor but I cannot see any reason why it would not work on TEL IN. TEL IN is connected to TEL OUT via a normally closed relay so there is nothing between them when comfort is not dialing out or beaing accessed remotely |
