Second Siren - Printable Version
+--- Thread: Second Siren (/thread-1049.html)
- Choppa - 05-09-2008
Hi all.
Is it possible to have a second siren connected.
(eg) The main siren to go off like normal,the second one to only go off with a  intruder in away mode.
- admin - 05-09-2008
You can connect a relay (RLY01) to an output which could drive a second siren.
The action of the output turning on or off would have to be programmed in Comfigurator as you require
Hi.
Thanks for the reply.How would be the best way to do that?
Choppa.
You say you want the siren to turn on only if there is an alarm in Away mode
In alarm types > Intruder  Alarm, program the Alarm Response as follows
If  SecurityMode = AwayMode Then
    Output Output01 On
End If
Assuming Output 1 is connected to the relay and siren
In Alarm Types > System Disarmed
Output  Output01 OFF
