Holiday Programs and Holiday Mode - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: Questions on Using Comfort (https://www.comfortforums.com/forum-159.html) +--- Thread: Holiday Programs and Holiday Mode (/thread-1039.html) |
- Guest - 05-02-2008 In the Comfort I training manual it states that Holiday programs will only start to run on the next day after setting to Holiday Mode. Why is this? If I go on holiday at midday, I would want my semi-random holiday programs to run eg that evening to switch lights on and off. Is it the same in Comfort II? Will the Time Programs run if just Holiday is set and not Mon-Sun and the time is after going into Holiday Mode or do they not run until after midnight also? Incidentally, is there an equivalent to the Comfort I traning manual for Comfort II? If not, where are these vital gems of information to be found? Sorry to ask so many questions all at once but they are related. Thanks and regards Adrian. - admin - 05-03-2008 Adrian I believe the Vacation (Holiday) Programs will run on the same day in Comfort II For Time Programs if the day is a Holiday OR is the system is set to Vacation Mode, the Time Program will run if Holday is checked We use the term Vacation Mode instead of Holiday Mode to avoid confusion between the Vaction Mode and the use of Holiday in Time Programs There is not a single training manual, but if you go to https://www.cytech.biz/techinfo.html you will find a lot of training material from Training slides, configuration, wiring guide etc - Guest - 05-04-2008 Thanks for your help. A |
