Door Strike Configuration - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: Questions on Using Comfort (https://www.comfortforums.com/forum-159.html) +--- Thread: Door Strike Configuration (/thread-1009.html) |
- Jesmond - 04-06-2008 Hi Guys, I am configuring a Comfort Ultra for the first time and need to control a door strike which I have connected in the following way: OP1 on Mainboard -> OP1 on RLY01 and NC1 / COM1 on RLY01 - > Strike I have absolutely no idea how to program comfigurator to make this work.... and could not find any documentation on same. Can someone point me in the right direction... Regards Jes Camilleri - admin - 04-06-2008 You can control outputs by switching ON, Off, Toggle or Pulse eg Output Output01 On wil switch the output (and relay) On Output Output01 Off Will switch the output off Pulse Output01 For 20 will pulse the output for 1 second (units are in 50 ms) These output actions can be found in Events > Responses The Pulse action is the most suitable for your door strike You create a Response with the Pulse Action and assign the Response to the Open Door or Open Gate event in Events > Misc Events. In the Door station menu, this will allow you to hear the announcement Press 7 to Open Door (9for open door response) or Press 4 to open Gate (for open gate Response) You can also assign teh Response in the Home Conrtrol menu to you can open the door without having the doorbell ring |
