DM interface - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: Questions on Using Comfort (https://www.comfortforums.com/forum-159.html) +--- Thread: DM interface (/thread-1000.html) |
- petrkal - 03-30-2008 Can comfort combines (via DM02 MODULE ) with other doorphones with cameras (like DoorGuard400 LCD Colour DoorPhone System)? Thanks - admin - 03-31-2008 The DM02 connects to external door stations via 5 connections Mic, Speaker, Doorbell button, Door release, common (see DM02 Manual in www.cytech.biz/manuals.html) If an intercom is an analog type ie it has these individual signals instead of a two wire data bus then there is a possibiity that it can be used with DM02 Fermax Cityline has been tested wuth DM02 so we advise people to use this instead of ither brands that have not been tested Also the new Cytech DS01 metal Door station can now be used with the DM02. This has flush mount and surface mount options and has a monochrome and colour camera versions. It performs well for intercom purposes See picture |
