Integration with Homeseer - Printable Version
+--- Forum: Software Tools and Misc Interfaces (https://www.comfortforums.com/forum-27.html)
+--- Thread: Integration with Homeseer (/thread-969.html)
Pages: 1 2 3 4 5 6
- Ian - 11-13-2018
@Slychiu thank you for contributing on the HS forum.
- slychiu - 11-14-2018
I hope a good driver can be produced
- posixx - 11-14-2018
Hello Comfort users,
I was noticed by Chiu for this thread existence. I\'m currently developing a native homeseer plugin for comfort. I\'m currently using in on my HS system and it works perfectly, only need to iron out some small bugs. The plugin supports connecting to comfort trough network, serial and USB, just like comfigurator. The plugin needs the comfigurator configfile (you need to upload it using the plugin) so it knows zones and responses. You can choose which zones and responses need to be available as homeseer devices.
Some screenshots attached.
Regards,
Frans
Select zones which need to be HS devices:
Select response which need to be HS devices:
Result of selections:
Actions are available as well as events based on change. I hope to finalize first release before the end of the year.
Regards,
Frans
- Ian - 11-14-2018
That looks fabulous - well done.
If you need a tester, happy to help.
- slayer91 - 12-01-2018
Great work, put me down for another buyer when it comes available.
Regs
Liam
- posixx - 12-18-2018
The comfort plugin is available as of this moment:
 https://shop.homeseer.com/products/posixx-cytech-comfort-software-plug-in-for-hs3
Please discuss issues etc in the homeseer forum:
https://forums.homeseer.com/forum/security-systems-plug-ins/security-system-discussion/cytech-comfort-posixx
Help for setting up the plugin: https://plug-ins.mijnhomeseer.nl/cytech-comfort-plug-in/
Regards, Frans
