Internet access to Comfort - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Software Applications (https://www.comfortforums.com/forum-4.html) +--- Forum: ComfortClient (https://www.comfortforums.com/forum-65.html) +--- Thread: Internet access to Comfort (/thread-689.html) |
- juwi_uk - 03-07-2009 I\'ve done a bit more work today and 1.0.5.0 now does background and foreground colours so you can make some very gaudy floorplans! ![]() J - juwi_uk - 03-09-2009 Hi This is how the label properties box looks in the 1.0.70 version that\'s in development. Most of the settings change the attribute of the label, font, size, colour, alignment etc) \"Text\" is pricipally for static labels on the page. When Comfort Type is anything other than \"*STATIC*) the application will take the basic counter value (20 say in my Smartfit example) and then add whatever you have in the prefix/postfix fields (in my example attached the label say \"Temp: 20 \'C\"; where \"Temp:\" and \"\'C\" are the prefix and postfix respectively) Do you think this covers all of the bases? Regards Julian p.s anyone know where there are any good freeware clipart of things like trees, bushes etc that would be suitable for inclusion in a set of bundled objects? Also note by the way that I\'m running on Vista Utlimate 64bit with Aero; hence the transparent borders!! - juwi_uk - 03-10-2009 Hi, There\'s a new 1.0.7.0 version if anyone wants to play. You can get it from my FTP areas as per the link I posted earlier in the thread. Julian Changes are: Bug Fixes
- mrtae - 03-10-2009 Hi FYI...The file in your FTP directory not zip...else have to download 1 by 1 file. thanks.. - juwi_uk - 03-10-2009 Oops, sorry. Try now. I emailed the files to you seperately this morning (GMT) so should be in your inbox. Regards Julian - juwi_uk - 03-10-2009 Hi, 1.0.8.0 is underway and 2 new features added already: (1) Sensors (SCS Temperatures) are now supported. (2) Support Celsius to Farenheit conversion and vice versa when \"Comfort Type\" is either \"Counter\" or \"Sensor\" and is flagged as a Temperature value. See the screenshot below; you set the \"Native\" temperature scale and the \"Required\" (what you want it set too). See screenshot below on where you set. Let me know if you want and I\'ll freeze the build and post a link, otherwiase I\'ll crack on adding more features. Regards Julian - juwi_uk - 03-13-2009 Hi, I\'ve created 1.0.8.0 version, available at the FTP address earlier in this thread if anyone wants to download. Changes are: Regards Julian Quote:Bug Fixes - ident - 03-14-2009 When connnecting to our office using an IP address, the connect button did not manage to connect via (dynalmic) IP address and Port manually entered The UCM Login gave an exception See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.NullReferenceException: Object reference not set to an instance of an object. at ComfortClient.ComfortClientMain.SendComfortLogon(String ComfortLogon, String LogString) at ComfortClient.ComfortClientMain.Logon_Request() at ComfortClient.ComfortClientMain.Logon_Click(Object sender, EventArgs e) at System.Windows.Forms.Control.OnClick(EventArgs e) at System.Windows.Forms.Button.OnClick(EventArgs e) at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ButtonBase.WndProc(Message& m) at System.Windows.Forms.Button.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ************** Loaded Assemblies ************** mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3082 (QFE.050727-3000) CodeBase: file:///c:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll ---------------------------------------- ComfortClient Assembly Version: 1.0.8.0 Win32 Version: 1.0.8.0 CodeBase: file:///C:/work/download/Programs/Cytech/ComfortClientPreview/ComfortClient.exe ---------------------------------------- Microsoft.VisualBasic Assembly Version: 8.0.0.0 Win32 Version: 8.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll ---------------------------------------- System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- System.Runtime.Remoting Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll ---------------------------------------- System.Configuration Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll ---------------------------------------- System.Xml Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3082 (QFE.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- TdmUserInterface Assembly Version: 2.4.0.276 Win32 Version: 2.4.0.276 CodeBase: file:///C:/Program%20Files/Wave%20Systems%20Corp/Trusted%20Drive%20Manager/TdmUserInterface.dll ---------------------------------------- ************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging=\"true\" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box. - juwi_uk - 03-14-2009 Hi Did previous versions work OK? As far as I\'m aware I\'ve not changed any of this code for a couple of releases except this time moving the file settings to another form. It\'ll try to connect based on the IP and port # read from the Comfigurator file you have entered. Is there a scenario where your CCLX doesnt have an IP adress or port in the config; ie you connect serially or something as I might not have trapped this. However if you check the box next to the port # and manually type an !P address (or domain name) and port; does this work? A screenshot might help too. Julian - juwi_uk - 03-14-2009 Actually, another thought. Quote: \"When connnecting to our office using an IP address, the connect button did not manage to connect via (dynalmic) IP address and Port manually enteredIf you mean you are using DHCP with a short lease and the client is not connecting because it\'s trying the old expired IP address (because the comfigurator file IP address is expired too) then check the manual entry checkbox and use the name of the device instead in the IP address field. Let me know. Regards Julian |
