Problem with send message from c-bus to knx - Printable Version
+--- Forum: C-Bus to KNX Translator (https://www.comfortforums.com/forum-103.html)
+--- Thread: Problem with send message from c-bus to knx (/thread-4585.html)
Pages: 1 2 3 4
- slychiu - 02-03-2017
That does not seem possible that Lighting application would not work now. Are you absolutely sure?
can you change the Lighting application to Custom but use the same application 56 and see if there is any difference>
- m.j.sorokin - 02-03-2017
I thought in a moent there is a problem with the application coverage.
When you add the address of the Heating Application â„–136 ($ 88), addresses of the Lighting Application 56 ($ 38) is not transmitted to the KNX network.
And the second problem is that when you add addresses from a variety of custom applications, you can not assign them the same type. Like on the picture:
- slychiu - 02-04-2017
Quote:When you add the address of the Heating Application â„–136 ($ 88), addresses of the Lighting Application 56 ($ 38) is not transmitted to the KNX network.
Do you mean that when you add application 136 addresses, ALL Lighting application cannot be sent from Cbus to KNX, or just the group addfress that was used in 136?
- m.j.sorokin - 02-04-2017
When I use the groups from Application 136, the groups from aplication 56 is not transmitted to the knx. But groups from aplication 136 is transmitted to the knx.
for example:
If you use applications 56 and 48
Groups Apl 48 to KNX - ok
Groups Apl 48 from KNX - ok
Groups Apl 56 to KNX - ok
Groups Apl 56 from KNX - ok
If you use applications 56, 48, 136
Groups Apl 136 to KNX - ok
Groups Apl 136 from KNX - ok
Groups Apl 56 to KNX - dont transmit
- slychiu - 02-05-2017
are you sure you have done a write to EEPROM after the latest change?
Many people forget especially if ythey have done a few changes
Try a read from eeprom and see if the table cbus to knx is what you expect
after doing read from eeprom, plrease savbe and send the cclx file to support@cytech.biz so we can test
- m.j.sorokin - 02-05-2017
[user=1]slychiu[/user] wrote:
Quote:are you sure you have done a write to EEPROM after the latest change?
Yes, I did such a test when a fault is identified.
Tomorrow I\'ll send the configuration from the device.
- m.j.sorokin - 02-06-2017
Quote:plrease savbe and send the cclx file to support@cytech.biz so we can test
Config from device in attacment. But its btcx file...
- slychiu - 02-21-2017
We have managed to duplicate the bug when using Custom application causing the lighting application from cbus to KNX not to work
A new firmware should be available soon after our testing
