Relay wiring - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: Relay/Automation Modules (https://www.comfortforums.com/forum-118.html) +--- Thread: Relay wiring (/thread-4974.html) |
- david8811 - 12-13-2018 Hi Mr Chiu, Thank you for your response. I am using Engineer Menu Programming, the link you sent seemed to be not addressing my questions. To diagnose why Response 6 is not activated, I decided to carry out a test without the Start Timer Response 194 code, but added in action code 116 to played warning message. So I changed Response 45 from 73, 3, 69, 19, 70, 6, 193, 74, 5, 194, 1, 0, 5, 6, 255. To 73, 3, 69, 19, 70, 6, 193, 74, 5, 74, 116, 74, 6, 255. Step 1 - When I walked past the PIR, the PIR triggered and itââ¬â¢s LED activated, Relay activated, Bulb lighted up, warning message played on keypad, but bulb didnââ¬â¢t turn OFF. Step 2 - When I walked backwards to trigger the PIR again, the Relay deactivated, warning message played again on keypad, bulb turn OFF. Then, I walked past PIR again, Step 1 repeated. If I walk backwards to trigger the PIR again, step 2 repeated. It seemed that Output 3 requires Retriggering of PIR to activate Responses 5 and 6 alternately. Why is it behaving this way? Strangely, Step 2 wouldnââ¬â¢t happen to Response 45 with original codes of 73, 3, 69, 19, 70, 6, 193, 74, 5, 194, 1, 0, 5, 6, 255. - david8811 - 12-14-2018 Hi Mr Chiu, I changed and repositioned Response 45 Action Codes by including Start Timer Action Code 190 for 10 seconds before Keypad plays warning message and switch OFF Output 3. Thus, Response 45 was revised from 73, 3, 69, 19, 70, 6, 193, 74, 5, 74, 116, 74, 6, 255. To 73, 3, 69, 19, 70, 6, 193, 74, 5, 190, 0, 10, 74, 116, 74, 6, 255. When I walked past PIR, Relay was activated, bulb lighted up, but NO warning message played on keypad and Response 6 to switch OFF output 3 was not activated too. This test concluded that the system is unable to execute Start Timer Action Codes, Both 190 and 194. Appreciate if you could advise the solution to this problem. - slychiu - 12-14-2018 Your problem is that your actions are wrong 73,3, 142,10,19, 143,7,6, 193, 74,5, 74,116, 74,6, 255means If Hours < 19 Then If Hours >= 6 Then Exit Response Do Output3ON Do Reminder8OnKeypa Do Output3OFF End If End If Exit response ends the response so the following actions have no effect If what you want is If Hours < 19 Then If Hours >= 6 Then Do Output3ON Do Reminder8OnKeypa Wait 1 Seconds Using Timer01 Do Output3OFF End If End If The actions are73,3, 142,13,19, 143,10,6, 74,5, 74,116, 190,1,0,1, 74,6, 255 The 2nd set of actions73, 3, 69, 19, 70, 6, 193, 74, 5, 190, 0, 10, 74, 116, 74, 6, 255 Is also wrong action 190 should be190, timer#, timerhi, timerloyou may have wanted 190,1,0,10, NOT 190,0,10 That is the problem with trying to write raw action codes. you need to have a good knowledge of the actions These errors would not have happened using Comfigurator - david8811 - 12-14-2018 Thank you Mr. Chiu, This new Action Codes 73,3, 142,13,19, 143,10,6, 74,5, 74,116, 190,1,0,1, 74,6, 255 that you suggested didnââ¬â¢t activate any actions at all. Then I tried my earlier Action Codes with correction on the Timer Number that I missed out. and brought foraward Response 116 before Start Timer 190. Here is the Action Codes 73, 3, 69, 19, 70, 6, 193, 74, 5, 74, 116, 190, 1, 0, 10, 74, 116, 74, 6, 255 Step 1- When tested, it triggered the Relay, bulb lighted up and warning message played on keypad, but it didnââ¬â¢t switch OFF Output 3. Step 2- When I walked backwards to retrigger the PIR, then it replayed the warning message and switched OFF output 3 and the bulb. Step 1 and 2 can be repeated to switch On and Off the light. Why the Timer function is not responding? - slychiu - 12-15-2018 I still do not know what firmware you haveYou may have Optimum which has different actions Take a photo of the Main Board. check the label on the IC which says \"ULT\" or \"OPT\" If we do not know this then and do not have a cclx time we are wasting time - david8811 - 12-15-2018 My system is ULT , 7,xxx - slychiu - 12-15-2018 There is something that you have programmed wrongly or reported inaccurately or missed out It is not possible for us to help from here You will need to go through all your responses and actions and find out exactly what each action means, and check all the called response numbers. If you had UCM you could send the cclx file and we could analyse it. but if you program by keypad we cannot help much - david8811 - 12-15-2018 What is teh difference of using Timer No. 1 or 2 or 3 in a Start Timer Action Codes? - slychiu - 12-15-2018 You can use any timer.There is no difference between timers Just use one timer for 1 function Do not use the same timer for different functions see http://www.comfortforums.com/view_topic.php?id=4062&forum_id=92 for fuller explanation Timers are a well established function and have been used in many installations for 20 years. There is no problem with operation of timers if the actions are coded correctly |
