Comfort 1 announcing tamper fault - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Problems & Troubleshooting (https://www.comfortforums.com/forum-36.html) +---- Forum: Comfort I Issues (https://www.comfortforums.com/forum-101.html) +---- Thread: Comfort 1 announcing tamper fault (/thread-4232.html) |
- John W - 06-28-2015 The main panel was fitted in 2001, which uses a microswitch and worjs fine. the sep was fitted in 2009 and uses a round plastic plunger switch. It came with a spare switch, which I tested too and that acts the same. no false alarms today so I am hoping that is it, fingers crossed ! I am now thinking it could be time to upgrade to a comfort 2 pcb. Is there a comfort 3 in the pipeline ? (If there is I will wait for it, I\'ve waited this long) - admin - 06-29-2015 There is always new versions in the pipeline no mater when you upgrade, but it would not be for another year or 2 If you have shorted the tamper then you should not have any tamper problems again - John W - 06-29-2015 Thanks. No tamper yesterday, yay !! Fingers crossed it\'s fixed. I\'m thinking of upgrading the pcb and Ethernet ucm so I can use the comfort apps, and get away from serial port for configurator. If the main pcb is about to be revised then I would wait (eg I saw the discussion regarding dropping x10 in favour of Ethernet). I still use x10 for remote control of garden lights, so hope it doesn\'t get dropped... I will send a message to determine cost and where to buy the upgrade should I decide to proceed. Many thanks, John. |
