Night Mode - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: Questions on Using Comfort (https://www.comfortforums.com/forum-159.html) +--- Thread: Night Mode (/thread-384.html) |
- jon_itmagic - 05-22-2008 When I press the Night Arm button, I get 8 single tone beeps, each at 1 second intervals. There are no open zones whilst arming. Attached is a screenshot of my sound and siren types. - jon_itmagic - 05-26-2008 Any suggestions please???? - admin - 05-26-2008 We are looking at this and will get back to you Sorry for the delay, we have had a busy time this last week - ident - 05-26-2008 Your problem from looking at the Siren Types screen is that the Siren Type for \"Arming Tone\" is set to \"Slow Beeps\" instead of \"Silent\" - jon_itmagic - 05-26-2008 [user=86]ident[/user] wrote: Quote:Your problem from looking at the Siren Types screen is that the Siren Type for \"Arming Tone\" is set to \"Slow Beeps\" instead of \"Silent\" OK - I changed \'Arming Tone\' from \'Slow Beeps\' to \'Silent\', but I\'m still getting the same beeps through the keypad! That aside, if this proposed fix were to work, surely changing the \'Arming Tone\' to silent would disable the beeps for all modes (night, away etc...) This is not what I want. All I want to do is disable the beeps when selecting night mode. - admin - 05-26-2008 Can you send your full ccl file so that we can check what you have done. Use Comfigurator 2.2.3 as it will show the firmware and system information in the file You are correct that this method will disable beeps in all modes I suggest that you shorten your night mode arming time in the Night Exit Time setting to 2 seconds I do not know of any other way to silence the arming tones in Night mode only - admin - 05-26-2008 I forgot, the email to send the ccl file is support@cytech.biz thanks - jon_itmagic - 05-26-2008 Sent, as requested. Thanks. - admin - 05-28-2008 Solution found! The Siren Type \"AutoArming\" is used for Night Mode and Auto-arming beeping tones by Time Programs. The Siren Type \"Arming Tone\" is for Away Mode arming beeping tones Hence to disable the night mode arming beeps, set \"Auto-arming \" Siren Type to \"Silent\" |
