Zone Type - Printable Version
+--- Thread: Zone Type (/thread-1418.html)
Pages: 1 2 3
- dcrera - 12-02-2014
I forgot how to do this. How do you get a open zones to do a short beep on the keypad ?
- CytechMartin - 12-03-2014
In the Zone On/Off response, you need to create a response to activate the beep on keypad.
\"Append New Action\"--->\"Output\"--->\"Activate siren\" Then you can select all the siren type on right window.
- dcrera - 12-03-2014
Not the siren, a small beep on the keypad is what I am looking for.
The siren blew off my ears. I don\'t want to wake the neighborhood.
- CytechMartin - 12-04-2014
You can see that in the Siren Type Name, you can select those types , e.g. Chime, Beep. Normally Chime is used as it has short duration(2s).
- dcrera - 12-04-2014
Cool, thanks
The Siren types I have on my list goes from SirenType1 to SirenType20 unlike your drop down list.
- CytechMartin - 12-05-2014
The names of Siren Types can be changed yourself. The most important is the property of each siren type. Here is a default one, you may know which one is \"Chime\" by comparing the property
- slychiu - 12-05-2014
The reason why you see siren type numbers instead of the default names is because you may have done a Read from Comfort. The names are not saved in Comfort, only the properties, so when you read from Comfort, the names are replaced with the siren number
You should rename your siren types according to the defaults so it is easier  to select a siren type. You can open any default template to see the defaults
This topic will be closed as it has too many posts and has departed from the title \"Zone Types\"
Please start a new post if you wish to ask or post about a new Topic and now Reply to an old post which is not related
