Comfigurator 2.9.1-2.9.9 Beta - Printable Version
+---- Thread: Comfigurator 2.9.1-2.9.9 Beta (/thread-1088.html)
Pages: 1 2 3 4 5
- admin - 12-22-2008
Comfigurator Beta 2.9.8 is now available for download from
https://www.cytech.biz/Default.aspx?cmd=sQ0OYE9X66w%2b0P%2bAcFsmAI3j73Rwtfrj&fileid=203&dcid=4&pageindex=
This fixes bugs reported in 2.9.7
It should be quite close to a release version so please try it out
- juwi_uk - 12-22-2008
Any chance we can have the \"EXECUTE\" button back on the Control Menu as was useful in 223 for firing X10 stuff.
- malgre - 12-22-2008
I\'ve added this, so it will be available in the next version.
Malcolm Green
- juwi_uk - 01-02-2009
In the UCM section any reason why there is not a formal type for \"UCM/Ethernet\"?
Think this was same in current release but seems a little strange given that about every other variant is listed in the dropdown list.
J
Is there any documentation that describes how \"Room responses\" and \"Sensor Responses\" are used.  I can\'t see how they link to physical/hardware.  Sensor 0 (\"Sensor 00\") for example;  what I/O card is sensor physically plugged into?   I\'m confused!!  :?
Looked in current configurator manual but nothing in there that helped.
help...
- admin - 01-03-2009
Quote:In the UCM section any reason why there is not a formal type for \"UCM/Ethernet\"?
J
There is no separate UCM/Ethernet listed because this is the same as a UCM05 (RS232) but with a serial to Ethernet converter.
All the other types eg C-Bus, EIB, GSM etc implement different communications protocols, hence  Comfigurator needs to know how to talk to them
Quote:Is there any documentation that describes how \"Room responses\" and \"Sensor Responses\" are used.  I can\'t see how they link to physical/hardware.  Sensor 0 (\"Sensor 00\") for example;  what I/O card is sensor physically plugged into?   I\'m confused!!  :?
help...
Room Responses are triggered by the RC01 Remote control when pointed to a keypad or IRD01 dome
Look in the RC01 Manual for this, also see this topic
http://www.comfortforums.com/view_topic.php?id=321&forum_id=50
Sensor Responses are activated by the temperature sensor in the Scene Control Switches. See the forum on SCS http://www.comfortforums.com/forum57/443.html
The manual of SCS is also found on the www.cytech.biz/manuals.html
- juwi_uk - 01-03-2009
Getting an issue with 2.9.8 and Smartfit config.  Works Ok in 2.2.3.
Get errors even with Smartfit demo CCL.
See screenshots.
Help...:?
Could we have ability to import CRS type files in 2.9.x as you are only allowed to open CRX ones at the moment.  Found when I tried to export some responses out of an old CCS file into 2.9.8.  Worked around by converting CCL to CCLX and export/import this way but direct import would be good.
J
Getting this error on opening my CCLX file.  Any way to get out of?  I just deleted a response and got this error.  I chose not to SAVE on exit but still got when I reopened file (so did it save anyway...?).
Error is:
Unhandled exception:
System.NullReferenceException: Object reference not set to an instance of an object.
   at Comfort.ActionX10Command.Encode()
   at Comfort.Response.GenerateActionCodes(Configuration configuration)
   at Comfort.Response.EncodeResponses(Configuration configuration)
   at Comfort.Form1.SetNewConfiguration(Configuration newConfiguration)
   at Comfort.Form1.OpenFile(String filename)
   at Comfort.Form1.OnMruFile(Int32 number, String filename)
   at Comfort.MruStripMenu.OnClick(Object sender, EventArgs e)
   at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
   at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e)
   at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
   at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
   at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met)
   at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met)
   at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
   at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
   at System.Windows.Forms.ToolStrip.WndProc(Message& m)
   at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
I still have the CCLX file.
