Bus wired sensors? - Printable Version
+--- Thread: Bus wired sensors? (/thread-915.html)
Pages: 1 2
- ekarak - 07-27-2011
Hello all!
happy to pick up an old thread, but this is a flaming issue!! When a prospective client comes to see Comfort, first question is: can I replace my old alarm panel with this?
My answer right now is : \"Yes but with some additional cabling...\" : wrong answer, in existing houses you dont want to rip out existing cabling and start cabling all over the place...
The reason is most alarm cablings are cost-centric: as little wire as possible, run the same loop all over the perimeter etc etc.
1-wire (http://en.wikipedia.org/wiki/1-Wire) would be an ideal candidate for bus sensors. Low powered sensors are its main focus. just a pair of wires (signal & ground) to talk to devices up to 1000m away. with power coming in from Comfort\'s battery it should be easy doing it
I\'m not sure about standards compliance though, I don\'t know what timing limitations or encryption/tampering prevention functions should be implemented.
- ident - 07-28-2011
1-wire is possibly something to be investigated
However you do not have to take out the exiting alarm wires to replace an existing alarm with Comfort. The alarm  wires can stil be used, only that the keypads need CAT5 cable and need 6 wires whereas alarm keypads nornaly use 4 wires as theyu dont carry voice
