Comfigurator 2.2.3 - Printable Version
+---- Forum: Comfigurator 2.X (https://www.comfortforums.com/forum-67.html)
+---- Thread: Comfigurator 2.2.3 (/thread-873.html)
Pages: 1 2
- ndh - 04-02-2008
Sorry, but I just can\'t see it!
What Action button and item no. do I use in the Wizard to get the second line here:
Output Output07 On ! Output goes on
! Can\'t see how to do this line from the Wizard
Omit FrontDoor ! Omit the Front Door
Nigel
- admin - 04-03-2008
You cannot put in a comment by itself on a line.
Comments on each line after an action have been implemented in 2.2.3
if you need to do so I suggest after the wizard when you review the response, go into Manual and add in comments on separate line as needed. At this poimnnt you are in a bettr position to think what coments are needed rather while you are trying to enter the action
- slychiu - 07-29-2008
Bug discovered in Comfigurator 2.2.3 (probably older versions as well). The use of Timer 64 will cause an \"Unknown Exception\" Error
If you have used Timer 64 which results in Unknown Exception, use a text editor to change Timer 64 to another timer
- slychiu - 10-24-2008
Bug discovered in 2.2.3. When OPTIMISE RESPONSES is checked in Options menu, the Sunrise and Sunset Responses are disabled. Please uncheck the OPTIMISE Response option
- slychiu - 07-27-2009
New Bug found in Comfigurator 2.2.3
Please take note of the following if you still use Comfigurator 2.2.3. This issue has been added to the \"known bugs\" list in the original post in this topic
When a \"Do Response After Timer\" Action is edited in Response Wizard AND the value of the timer is greater than 255, the wrong Timer name is selected in the drop-down list. When editing, please be careful to select the correct timer name before pressing OK
Even if you press OK without selecting the Timer, the action has the correct timer number, and does not use the incorrect timer number
