Firmware upgrade versions - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Problems & Troubleshooting (https://www.comfortforums.com/forum-36.html) +---- Forum: Firmware Upgrading Problems (https://www.comfortforums.com/forum-111.html) +---- Thread: Firmware upgrade versions (/thread-5469.html) |
- rodime - 02-13-2024 MPU01 is now installed and firmware is showing in system information as 7.164. However, when I try to update comfort from Comfigurator, pressing F0 on the keypad and entering the engineer code on the laptop, I\'m getting an error, \"Please enter the Engineer code, not a user code\" This was all working ok before and the engineer code hasn\'t changed. I confirmed I\'m able to log in to the keypad with the engineer code. Also tried resetting comfort but still the same error so at the moment I\'m unable to update Comfort from Comfigurator with my latest Response updates. - slychiu - 02-14-2024 The problem is that the engineer user number was changed from 18 to 254 in 2011 to allow more more user codes. But Comfigurator 2 expects the engineer user to be 18 hence the error. You can downgrade the firmware to ULT 6.007 attachedwhich was the last firmware to have engineer user number 18. I recommend to change to Comfigurator 3 as soon as possible. Both Comfigurator 2 and 3 can be installed in the same PC This post clarifies http://www.comfortforums.com/view_topic.php?id=5475&forum_id=67 - rodime - 02-14-2024 Couldnât I also disable the MPU with J14 shorted? So going back to the built in firmware 5.045, running the response update and then removing J14 and going back to the MPU? As a temporary solution at least. If so, can I do the J14 short and revert without shutting the power down or better to power down completely, then short, then power up? And just to confirm I can indeed leave the MPU in place when shorting J14, I donât have to remove it to go back to underlying 5.045 as long as J14 short is in right? I canât go back on the firmware because I donât think I can update the comfort firmware with a programming cable and my current UCM/RS232 although please confirm there because the label on the chip is firmware 5.92 which is above the required firmware version, but the system scan shows 5.092 which is below the required version. - slychiu - 02-14-2024 shorting J14 will reset the CPU so the firmware will not work at all. If you want to revert to the old firmware you will have to unplug the MPU. Quote:I canât go back on the firmware because I donât think I can update the comfort firmware with a programming cable and my current UCM/RS232 although please confirm there because the label on the chip is firmware 5.92 which is above the required firmware version, but the system scan shows 5.092 which is below the required version.5.092 is the same as 5.92. a lonmg time ago we only used 2 digits eg .92 but we later changed to 23 digits , thus .092 - rodime - 02-14-2024 Ok so unplug MPU but according to instructions the J14 needs to be shorted in order to use the underlying 5.045 chip. J14 was shorted in place while using 5.045, before I added the MPU and removed the short. So to be clear, I think these are the steps, please confirm:- 1. Power off 2. Remove MPU 3. Short J14 4. power on. Or can I indeed leave the short off on J14 in step 3? - slychiu - 02-14-2024 Sorry, you are correct. It has been a long time since I have used MPU01 about 15 years. Quote:Remove two position Shunt J14 in order to enable operation of the MPU01. J14 must be shunted when the onboard U1 is in control and removed when the MPU01 is in control You should be able to shunt J14 to allow the base board microcontroller to operate, without doing power off - rodime - 02-14-2024 Ok great, so does that also mean I donât in fact have to remove the MPU01 and I just simply leave it in place and change the J14 shunt to enable the old 5.045 firmware? And also separately to confirm, the UCM/RS232 with 5.092 canât upgrade the comfort firmware correct? - slychiu - 02-15-2024 Correct on both questions - rodime - 02-15-2024 Thanks. And do I need to power down before moving J14? Iâm assuming comfort canât just change firmware mid flow without some kind of shut down or reset? - slychiu - 02-15-2024 Yes please power down before changing the shunt |
