KP06 stopped working - Printable Version
+---- Forum: Keypad (https://www.comfortforums.com/forum-69.html)
+---- Thread: KP06 stopped working (/thread-5365.html)
Pages: 1 2
- Ian - 02-11-2022
Done. :-)
- Ian - 01-16-2024
I ordered a replacement, I asked for the module that contained the speaker for a KP06. I received the speaker in the attached photo. As can be seen the speaker is larger than the grill on them module. Before I get back in touch with the supplier, can anybody confirm that this is not the speaker that fits inside the module?
- slychiu - 01-17-2024
That is not the correct speaker for KP06A. You need the plug in module with lcd and speaker part number XA03-0015.  The actual speaker used in KP0^A is a 20mm speaker with wires that you need to solder, and you would need to dismantle the module. so I suggest the complete module replacement
- Ian - 01-17-2024
Thank you.
