Tracking Responses sending Cbus Commands - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Third Party (interfacing to Comfort) (https://www.comfortforums.com/forum-5.html) +--- Forum: CBus (https://www.comfortforums.com/forum-11.html) +---- Forum: UCM/CBUS Problems (https://www.comfortforums.com/forum-120.html) +---- Thread: Tracking Responses sending Cbus Commands (/thread-5110.html) Pages:
1
- Howser - 09-10-2019 I could not get Comfigurator to connect to the UCM, even though Comfort ServerManager detected the UCM. So I disconnected the UCM for a few seconds and connected it again. Now I cannot reproduce the problem. This is what I am getting from the Monitor >all55D0000A872476s >all55D0000A870991s >all55D0000A860992s >all55D0000A862477s <0508CA00020E32E7 <050938001A273F2A28499F >all5538000227405Al <0509CA00090E11 >all5538000228FE9Bl >all55380002284A4Fl >all55D0000A872476s >all5538000228FE9Bl >all55D0000A870991s The Cbus Logs no longer shows Comfort changing the GA. - slychiu - 09-10-2019 Look at it again when it happens again. Com,fort should not be sending back to the same GA - Howser - 03-08-2020 Am having a similar issue again, this time, every time the alarm status changes. So when the alarm status changes to Day Mode, the following are changed by comfort according to Toolkit;
- slychiu - 03-09-2020 If Comfort sends any messages to cbus it is due to the program. Comfiort will not randomely send messages Check the Day Mode Response in Misc events and Alarm Type Armed Response also check Alarms to Cbus in Cbus module - Howser - 03-09-2020 I have searched the Comfigurator project for Cbus2 CbusUCM 56 5 and Cbus2 CbusUCM 56 47, could not find any. I have checked the Day Mode Responses in Miscellaneous Events, they have no Response. - slychiu - 03-09-2020 pls send your cclx file to support@cytech.biz - Howser - 03-09-2020 Email sent. |
