Noobie help - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Questions on Installation and Connection (https://www.comfortforums.com/forum-123.html) +--- Thread: Noobie help (/thread-5076.html) |
- Home - 06-25-2019 OR there may be a spare U4 in the read write slot of the UCM? A - theshepherdmatt - 06-25-2019 sorry fella, i have no idea what you\'re talking about? but here is a photo of my ucm. - slychiu - 06-25-2019 The sockets are empty. The early ucms did not come with spare eeproms - theshepherdmatt - 06-25-2019 I dont suppose you have a spare MPU laying around that you would like to sell do you? I know laser sell them but I\'d rather get a second hand one as I still don\'t know if my PCB actually works? - slychiu - 06-25-2019 I thought you managed to upgrade your mpu to version 7? - theshepherdmatt - 06-25-2019 Yes I did, but cannot connect to UCM as I don\'t have login codes. I\'d like to wipe the MPU and start again but with the login it\'s just not happening.. - theshepherdmatt - 06-25-2019 Also I wanted to try and extract the old program files from the old UCM, but again it won\'t work without the login/engineer code. Being a security system there doesn\'t seem to be a \'back door\' way in but that\'s to be expected. - slychiu - 06-25-2019 I don\'t know if you mean the u4 eeprom or the mpuThe firmware is in the mpu If you have upgraded to version 7 then you don\'t need a new one. The program configuration is in the u4 eeprom. If you have lost the engineer code then you need a new u4, not an mpu - theshepherdmatt - 06-25-2019 oh? thats good news.. it looks like my setup doesn\'t even have a U4? - slychiu - 06-26-2019 It is not clear from the photo if the U4 Socket is emoty or there is an IC inserted |
