Partitions on app - Printable Version
+---- Forum: Wishlist (https://www.comfortforums.com/forum-66.html)
+---- Thread: Partitions on app (/thread-4995.html)
Pages: 1 2
- Home - 01-14-2019
The Control menu (under \"Control\") has 5 control groups each with 0-9 tree below that.
The only thing that you can add or delete are the phrases that name the menus or the responses!
I take it you are \"deleting the files\" in comfigurator and not in the app or in notepad!
As Chiu suggests perhaps an example or .cclx file?
- Swiss-Toni - 01-15-2019
Exactly! you delete what you do not need for that partition. Hence you make copies so that you do not loose all information from main copy.
- Home - 01-15-2019
Chiu is it just me - I am totally lost !
Are you saying that you have a different app (file) for each partition?
What has partitions got to do with the home control menu? are you programming the home control menu to switch day night home and off !
Here try this.....You program the HC menu to operate partition 1 with day night away and off - load the app file as Partition 1
Re program the next menu with partition 2 ,day night away and off - load the app as Partition 2
Chui would this work !
- slychiu - 01-16-2019
I think he means you can have 2 profiles in the app, 1 for each partition.
However that may not work in the way that you want
t is better to assign the user different user codes for each partition,
eg
  • User 1 - Partition 0
  • User 2 - Partition 1
  • User 3 - Partition 2
  • User 4 - Partition 3
when you loig into the system sign in with the code assigned to the partition.
Then you can arm and disarm the assigned partition That is a simple solution, as Partitions are meant to be independent alarm systems
- Swiss-Toni - 01-16-2019
the partition does not seperate in HC in the app hence delete what is not required in the HC per user requirement!Which = different App per user.
- Home - 01-16-2019
So in the attached file Ive tried to do a work around on partitions
FIRSTLY - USERS SIGN INIf I only have 1 partition assigned per user then its clear that signing in as that user will give access ONLY to items with the same partition.
HOWEVER if i tick all partitions for a user, that user has access to all partitions - which physiclly is fine: go to keypad in garage sign in user 1 it arms/disarms the garage (partition1) : go to keypad in house sign in user 1 it arms and disarms the house (partition2).
If i now sign in on the app (or comfigurator) user 1 code and I arm or disarm ( in the case of Comfigurator in use mode) which partitions am I arming or disarming?
SECONDLY - control menu.  The .cclx file provides a control menu with alarm and home alarm and garage alarm both with feed back. The home alarm is PROGRAMMED with partition 1 arming and feedback: the garage alarm is programmed with partition 2 arming and feedback.
IF I HAVE THIS CORRECT, User 1 is assigned to partition 0, 1 and 2when user 1 signs in to pp th main arm and disarm will arm and disarm partitions 1 AND 2.
If he goes to control then home is partition 1 and garage is partition 2.
What happens in Comfigurator user mode?
- slychiu - 01-17-2019
You have almost got it right, but not quite.
If a user is enabled in more than 1 Partitions , eg 0,1,2,3, when he signs in via the app, he will go into the 1st partition ie 0 and arming and disarming will be for that partition
(of course using the keypad there is no problem as Keypads are assigned to 1 partition, so  the user has to be enabled for the partition of that keypad, eg Garage keypad will arm/disarm garage only if the user is enabled for that partition)
For your control menu, you have Home (Partition 1) and Garage (partition 2) Groups .
eg Arm Away  Home
If Partition = 1 Then
    AutoArm AwayMode
End If
Only user in partition 1 is allowed to arm Home
For the Garage
If Partition = 2 Then
    AutoArm AwayMode
End If
Only user in partition 2 is allowed to arm Garage
So if the user which is enabled for both partitions signs in, he will go into partition 1
He can arm the Home, but NOT the garage, because garage is only for partition 2.
So the solution for the Garage is
Set Partition = 2
AutoArm AwayMode
Look at the Partition Instructions download from https://www.cytech.biz/partitions_in_comfort.html which explains what are the actions applicable and how to achieve different tasks
- Home - 01-18-2019
What would happen if i set the USER 1 partition permissions to 0,1,2 and 3
Presumably this idea would then work for user 1 ? (or any other user that had those partition permissions ticked)
A
- slychiu - 01-19-2019
A user who is authorised for partition 1 and 2 would be able to arm Home and Garage by this program
Remember that is a user is authorsed for several  partitions, they will be logged into the 1st partition that they are authorised for eg 0
Any user would be able to arm the garage using the programOnly user for partition 1 would be able to arm the Home
You could also use the conditon \"If User number = \" to determine who can arm
