Pi Problems - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: UCMs (https://www.comfortforums.com/forum-146.html) +---- Forum: UCM/Pi (https://www.comfortforums.com/forum-138.html) +---- Thread: Pi Problems (/thread-4832.html) |
- DavidJ - 01-08-2018 Thanks for help. I managed to change the IP and now all works perfectly again, appreciate advice. - mattbrain - 01-08-2018 Just a quick follow up on this. The current (non commercial) solution does require the R-Pi, either via DHCP configuration on the router or by manually setting, to have a static IP address. This is compounded by needing to have internet access so it can reach www.alphawerk.co.uk. I am working on updating the code so the latter issue is removed and I am working on understanding the mitigation available on ST for the former issue. In other news, I am very excited to say that a prototype of a dedicated UCM is nearing completion which will allow for much tighter integration and broader IOT support - whilst nothing may appear to be in progress to followers of this forum, rest assured stuff is going on
- burtonjk - 03-04-2018 Afternoon all I have lost access to http://alpha-uhai.local today. First thing I noticed was that all my Comfort \'things\' went offline and following some diags found that I couldn\'t access the pi web service either via http://alpha-uhai.local or it\'s static IP. I can ping the pi, so my network connectivity is fine. I also cannot reach http://www.alphawerk.co.uk and wonder if this is related. Any help greatly appreciated Thanks Jim - DavidJ - 03-04-2018 Yes I guess there is a problem. I have spent all day assuming it was a similar DNS problem that I experienced a couple of months ago. Thanks to your response and the fact that the server cant be reached (which sadly was the final thing I tried) I assume its their server down. - wexfordman - 03-04-2018 Oops, looks like it\'s down for me also - schford - 03-05-2018 just noticed me too! Spent an hour toruble shotting till I thought to check the forums :-) - DavidJ - 03-05-2018 They are working on it. - mattbrain - 03-05-2018 Hi Guys I have just got back from a weekend on a charity fundraiser for Macmillan and only saw this issue earlier today when it was raised to my attention. This is as a result on an ongoing bug we are currently addressing. I anticipate the workaround will be complete in the next few hours and everything should start working as previously. We are working to overcome this issue on a permanent basis but it had been put on the back burner whilst we work on the new hardware platform. I\'ll try to bring this forward and make a patch available to overcome this specific issue. Thanks for your patience, Matt - mattbrain - 03-05-2018 Hi All It\'s back up - your systems should all start behaving well shortly. You can force it faster by pressing refresh in the comfort device in things. Thanks, Matt - rollem - 02-08-2019 Hi My RPi running the community edition has stopped responding. I can ping it and it replies but after connecting a monitor itââ¬â¢s just sat their at the alpha uhai login prompt. I canââ¬â¢t access the .local page either by direct link or using the static IP. The boot list shows everything loading correctly apart from the Hostname service which fails. I can access the Alphawerk.co.uk web page so donââ¬â¢t think itââ¬â¢s the same issue as reported in earlier posts on this thread. What could be wrong? Jon |
