Problem programming a response to access a second UCM/Z-Wave - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Third Party (interfacing to Comfort) (https://www.comfortforums.com/forum-5.html) +--- Forum: Zwave (https://www.comfortforums.com/forum-62.html) +---- Forum: UCM/Zwave Firmware (https://www.comfortforums.com/forum-93.html) +---- Thread: Problem programming a response to access a second UCM/Z-Wave (/thread-4635.html) Pages:
1
- slychiu - 02-22-2017 You can just change the ID and reset the UCM or Comfort. It should not affect the zwave mapping. Then do Scan for Modules again so Comfigurator can see that the ID has changed to 2 It may show a blank Zwave mapping (not sure abbout this), but if that is the case do a Read from EEPROM which will load the parameters from the UCM/Zwave If you have used mapping to Flags and Counters then no other changes are needed If you have used the zwave actions, check that the name reference to the UCM still works after your change of ID - Guest - 02-22-2017 I unplugged the UCM03 hardware, changed ID to 2 (from 3).). Replugged and rescanned. Comfigurator now thinks it\'s ID=2 but still called UCM03. Mapping intact. I then downloaded config to Comfort. Communication errors cleared. Doesn\'t seem to be any way of changing name. All seems to be working as expected with communication between Comfort and Z-Wave but 2 minor problems: 1) When I Rt Click on \"UCM03\" in the UCM Properties screen, the pop-up does not include \"Show References\" 2) After changing the mapping and downloading to Comfort, Comfigurator displays \"The configuration for module UCM03 has changed . . .\" When I click on \"Yes\" I get the error \"UCM 2 is not a UCM/Z-Wave\". However, clicking on Write to EEPROM works correctly. - slychiu - 02-23-2017 You can change the name of the UCM click on the UCM folder on the left. On the right pane you will see the 2 UCMs select the 2nd one and change the name on the right pane as shown in the attached screenshot. Do not select the UCM ID2 on the left pane In the screenshot, if there are references, then the UCM/Zwave will appear in Blue But references means you have actions referencing the UCM/Zwave. If uou map to flags and counters and sensors there will be no references I am not sure abnnout the last item. When you save and open the file again do you get the same error? - Guest - 02-23-2017 Thank you for your help. I was looking in the wrong place to change the name and see the responses though in my defence if I click on UCM02 in the left pane and then click on Name under the UCM properties, the help at the bottom suggests a right click will allow seeing references. Re the second problem, saving the configuration and re-loading triggers the dialog about writing to EEPROM and clicking YES works OK. It\'s only when the dialog is triggered by a download to Comfort that the error message appears. |
