Comfigurator 3.11.9 - 3.11.10 - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Software Applications (https://www.comfortforums.com/forum-4.html) +--- Forum: Comfigurator (https://www.comfortforums.com/forum-20.html) +---- Forum: Comfigurator 3.x Old Versions (Archive) (https://www.comfortforums.com/forum-87.html) +---- Thread: Comfigurator 3.11.9 - 3.11.10 (/thread-4558.html) Pages:
1
- Swiss-Toni - 12-15-2016 Having problems with using ver 3.11.10 Its knocking out my KT03 keypads, similar to a issue with a different version of comfigurator pre-partioning ver. The commands for alarms ect work however the keypad fails whe using a \"output\" command ie button for heating. the only way I could remedy this is to first use a version of comfigurator pre partioning Ver 3.9.7 and then use ver 3.11.6 to get my partions back and everything functioning again, through trial and error every time I have used ver 3.11.10 my KT03 keypads will not send commands for outputs.... - slychiu - 12-16-2016 Can yoiu give more details on this problem? After upgradong to 3.11.10, one of the KT03 buttons does not work? Did you write to Comfort and write to KT03 after the upgrade? If not there should be no change just upgrading Comfigurator Downgrading to 3.9.7 fixes the problem, but what did you do after downgrading?write to KT03 and Comfort? Please send thecclx file to support@cytech.biz and let us know which button does not work - Swiss-Toni - 12-16-2016 Will send CCLX file shortly, any button that opperates a output fails, and yes wrote to both comfort and keypads..... - slychiu - 12-18-2016 I dont think we have received the cclx file |
