window opener - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Questions on Programming Comfort (https://www.comfortforums.com/forum-83.html) +--- Thread: window opener (/thread-4310.html) Pages:
1
- Guest - 08-28-2015 I see.... this response can be associated to icon master command at KT03 ? Last question ... command for waiting open process finish before able to activate closing ? - Guest - 08-28-2015 I see.... this response can be associated to icon master command at KT03 ? Last question ... command for waiting open process finish before able to activate closing ? - slychiu - 08-28-2015 answer to both questions is yes - Guest - 08-28-2015 the 2nd question ...how ... :? BTW i just upload the program with \" set output On \" command...rly01h become not respond ... it respond with \"active pulse active\" command ... Am i missing something ? my program same as : Output OutputXXX On wait for30 seconds using timer 1O utput OutputXXX Off please see the acttachment - slychiu - 08-28-2015 The command are correct, but there is something wrong with the slave 2. It may not be connectedCheck the connections and modules |
