Comfigurator 3.10.3 to 3.10.11 - Printable Version
+---- Thread: Comfigurator 3.10.3 to 3.10.11 (/thread-4209.html)
Pages: 1 2
- slychiu - 12-18-2015
Bug in 3.10.10  beta
  • Missing file unmanaged.dll as described above
Bugs
  1. In Zwave, after doing a Learn from Zwave, Flag mappings are changed into Counters in Zwave Mappings in Comfigurator.  However this does not affect the actual mappings in the UCM/Zwave, only in the displayed mappings in Comfigurator. To workaround, do another Read from EEPROM for Zwave.
  2. [size=In Zwave, after doing a Learn from Zwave, Flag mappings are changed into Counters in Zwave Mappings in Comfigurator.  However this does not affect the actual mappings in the UCM/Zwave, only in the displayed mappings in Comfigurator. To workaround, do another Read from EEPROM for Zwave. ]
- Guest - 12-19-2015
my comfigurator is 3.10.6.0 ...why when check update ..system inform its the latest ?
- slychiu - 12-19-2015
3.10.6 is the latest released version. Others are beta versions
The following issues are not new to 3.10.10 but was reported wrongly as new issues;
  • Selective Read from blank template results in Blank Responses. Use Full Read to avoid this problem - This happens when eg Time Program or other item with a  Response is read by selective read contains a Response number which is not present in the Responses.  This results in the Response becoming Null.
  • After any Read operation, Comfigurator logs out by itself. This was the previous behaviour
- slychiu - 12-22-2015
Comfigurator 3.10.11 fixes the problem of missing dll file in the distribution
