Load Shedding - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: Questions on Using Comfort (https://www.comfortforums.com/forum-159.html) +--- Thread: Load Shedding (/thread-4125.html) Pages:
1
- dcrera - 04-04-2016 For confirmation, you can refer to my .cclx file I sent you Thanks again - slychiu - 04-04-2016 Measure the battery voltage at the battery connector when powering Comfort If it is less than 11.5 V there will be low battery alarm - dcrera - 04-04-2016 Old Battery voltage 13.02 New Battery voltage 13.38 New Battery on Comfort battery terminals 13.22 New Battery on UPS output 13.34 Seems like there is nothing wrong with my old battery - slychiu - 04-06-2016 I think there may be something wrong with your settings that we cannot see from here If non detector alarms for Power and Low battery are set to 0 then it is not possible for these alarms to be reported at all Can you try writing to comfort again when do you get these alarms after writing? Can you send the Event log as well - dcrera - 04-06-2016 I pm\'ed you |
