Cconnecting a Texecom Premier Elite Odyssey Bellbox - Printable Version
+--- Forum: Questions on Installation and Connection (https://www.comfortforums.com/forum-123.html)
+--- Thread: Cconnecting a Texecom Premier Elite Odyssey Bellbox (/thread-3717.html)
Pages: 1 2
- ident - 02-28-2014
I do not know what is the function of the Test Input of the bellbox
In Comfort you can test the siren and Strobe from the keypad by pressing
F3 4 for Siren Test - turns on the siren for 2 seconds
F3 5 for strobe 1 for on and 0 for 0ff
This does not need any connectuion to the test input of the siren
- rfs - 02-28-2014
[user=4987]avney88[/user] wrote:
Quote:Thanks again for the reply Wired home.
My question regarding the test connection was about the test input/output that is available on this Bellbox.
I would like to know if there is a way of making use of this connection for testing purposes via the Comfort and if so how could it be utilised.
If not my question was, is there a recommended method for testing the bellboxstrobe?
Hope this is clearer. :-)
The test input does not actually test the SAB audio and visual functions, I believe it\'s just a test of the internal workings etc.  You could wire this into any output on the Comfort which will apply 0V to the SAB and then there is a fault output which you need to wire back into the Comfort.
The way we test is during the annual/bi-annual maintenance inspection via the menus on the keypad.
