Heatmiser UCM - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Third Party (interfacing to Comfort) (https://www.comfortforums.com/forum-5.html) +--- Forum: Heatmiser (https://www.comfortforums.com/forum-42.html) +--- Thread: Heatmiser UCM (/thread-3703.html) Pages:
1
- John W - 12-31-2017 OK, thanks. I will contact heatmiser for details. - John W - 12-31-2017 The heatmiser modbus protocol is download able from here: https://www.heatmiser.com/en/protocol/ - slychiu - 01-01-2018 That is good. That means that you can use UCM/Modus-485 to control the Edge series - Ghyllwood - 01-04-2018 Just a little confused. You say - The wifi thermostats have been discontinued and are replaced by models which are not compatible with comfort. Yet the manual still refers to the wifi and having the sub module option for ETH03. Also the ETH03 sub module is still referenced as an accessory for the UCM/Heatmiser on the the Cytec web site. Am I right in thinking all of the references to WiFi are no longer relevant to UCM/Heatmiser and that only RS485 connections are possible? - John W - 01-05-2018 I might be wrong here, but I think the previous WiFi controllable variants aren\'t available now. Heatmiser now need you to have a neohub to control from their app, or use modbus. I\'ve not figured out any other way, but I am no expert, just trying to update ours too. - slychiu - 01-05-2018 Thats right, the wifi thermostats that could be controlled by ucm/heatmiser with eth03 have been discontinued so that is no longer an option, so that was a waste of time to develop We will have to amend the manual. |
