Bosch Blue line Gen2 PIR wiring advice - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Questions on Installation and Connection (https://www.comfortforums.com/forum-123.html) +--- Thread: Bosch Blue line Gen2 PIR wiring advice (/thread-3667.html) Pages:
1
- Guest - 01-06-2014 Hi Sam Thank you for your reply. Unfortunately no-one seems to be giving me the definitive answer that I have been looking for. I can\'t believe that I am the first to use the Bosch Blue Line Gen2 PIR with a Comfort II control Panel. Maybe you can work with IDENT to work out the correct connectivity to the NC & Tamper ports? Once again thanks in advance for any help. Avney - slychiu - 01-06-2014 Hi Sam, thanks for joining the forum and assisting with this question Avney, I believe Siamak has done a very good and clear connection diagram a few posts back. There is no problem with this Bosch PIR connecting to Comfort - if you follow the diagram, it will work fine. The + and - terminals should be connected to Comfort 12V and COM terminals respectively. Almost every PIR from major detector manufacturers have been used with Comfort. Let me know if there is something specifically that you do not understand from Siamaks diagram - Guest - 01-06-2014 Hi Slychiu and Cyamak, My apologies for not realising that I needed to scroll to the right to see the diagram. The post appeared blank on my screen until I went to the far right. The diagram is exactly what I needed, and I now understand what I need to do for the PIR connectivity. Thank you all for your help. Avney |
