Comfort 1 system advise - Printable Version
+---- Forum: Comfort I Issues (https://www.comfortforums.com/forum-101.html)
+---- Thread: Comfort 1 system advise (/thread-3606.html)
Pages: 1 2
- ident - 11-20-2013
For Comfigurator 3, go to View > Monitor I/O and check the box
This opens the Monitor IO window which shows what Comfort is doing
In comfigurator 3 you can \"check status\" of zones, outputs, flags, Counters
Check that the time in Comfort is correct
You can check if the LSM01 is giving oN or Off to Comfort
- mccltd - 11-20-2013
Ident with regards your last post I have downloaded comfigurator 3 and loaded my ccl into it.
When i turn on the monitor i/o I get commands show when things are happening but how do I decipher what they mean?
For example I just triggered my landing infra red and in the monitor it came up
ip0301
xtl1005
xtl0605
ip0300
Also I found the check status flags but the statuses show as unknown.
Does this only work with a comfort 2 panel?
- ident - 11-21-2013
IP0301 means Input 3 On
IP0300 means Input 3 Off
XT is an x10 message
you cann refer to the Comfort protocol whichcan be downloaded from https://www.cytech.biz/product_details.php?item_id=269 for details of messages
I am afraid the status flags may not work for Comfort 1
- mccltd - 11-22-2013
Thank you ident.
Something in my system is driving me crazy at the moment and I cannot work it out. Especially as I haven\'t changed anything.
Home could you please send me the clean cclx file. I presume I can load it into my comfort 1 system.
Also with this clean file does anything work? Ie once I have put my codes in will it function as an alarm it will it be totally unusable?
- mccltd - 11-28-2013
I notice in the upgrade 2 kit that it comes with a UCM/USB can this be upgraded to work on a network as well as i would like to use the iOS integration.
- ident - 11-28-2013
You can get an additional ETH03 submodule or to replace the USB. The submodules can be removed and exchanged. The Eth03 will cost more than USB
hmm can\'t find the eth03 in the Uk.
Would they be able to change the icm/usb in the kit to a ucm/eth3?
- ident - 11-29-2013
I suppose so, if you pay for the difference
