Remote access in and out - service - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Comments, Suggestions & Feedback (https://www.comfortforums.com/forum-22.html) +--- Thread: Remote access in and out - service (/thread-3482.html) |
- Home - 08-23-2013 OK So are yo intending to have UCM ETH and UCM ETH Email Or are we talking about just ONE single Ethernet UCM that can send e-mails as well ! - ident - 08-24-2013 Just one product thats all - juwi_uk - 08-24-2013 So I\'m still confused. Does this need new hardware then or is it going to be a firmware update ? - ident - 08-24-2013 It should be another ethernet plug in to replace the ETH02 - wexfordman - 08-24-2013 Is the plan to have it just for email, or would some form of push notification also be available for iPhone android app? - ident - 08-24-2013 Just the email sending function will be supported by the new module If you mean Notifications for the iphone and android apps, not at the moment, that is more complex and is a function of the app, not the Ethernet interface - wexfordman - 08-24-2013 In theory would it be possible to add that functionality to the app afterwards or would it be something you would look at? With email, I just find that you will tend to miss notification as you don\'t immediately address and email when it comes in, as it is a regular occurrence, whereas with am alarm notification you would react to . Just not sure if email notification is a full solution for something like security? - juwi_uk - 08-24-2013 Definitely not guaranteed delivery for sure. - juwi_uk - 08-24-2013 What else is new about this \"eth/3\" module; it must be because of more than just email. Newer/faster chipset, more memory? - wexfordman - 08-24-2013 Yep, email is fire and forget, so of it doesn\'t get read, no follow up. In an ideal world, if I was developing a new bit of hw or feature, I would link it to some sort of app or server where you had a watchdog alarm and then also your normal security alarms etc. You would not be able to have a watchdog reporting from comfort direct to the phone app as loss of coverage or service would cause the watchdog to activate, but if you were to have it report to a cytech server which the ap checked in on when it was in coverage. Might even be able to do something like that with email from comfort to a server. Maybe I\'m waffling again though, sorry |
