iPAD application - Configuration loading problem - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Software Applications (https://www.comfortforums.com/forum-4.html) +--- Forum: iOS Apps (https://www.comfortforums.com/forum-122.html) +---- Forum: Comfort iPad App (1st generation) (https://www.comfortforums.com/forum-116.html) +---- Thread: iPAD application - Configuration loading problem (/thread-3365.html) Pages:
1
- ident - 04-30-2013 The Bypass symbol is not for bypassing indiividual zones It is for Force arming If you try to arm the system but there are open zones they are shown on the app Pressing the \"Bypas\" icon will automatically byypass alll open zones and arm the system This is a better wway than bypassing individual zones - agenor - 04-30-2013 I have tried that, but nothing happens. I even tried holding the BYPASS button longer, but with no success. The \"Allow Force Arm\" parameter in the Modules and Settings tab is checked. - agenor - 04-30-2013 I\'m sorry. The bypass works fine. I was doing it wrong. Thank you. - agenor - 04-30-2013 One more thing regarding Home Control Menu on iPAD. I have tried the feedback types Counter, Flag and Output, but the status on the iPAD does not update after an On or Off command. Only when i kill the iPAD app and restart it the status is updated. - ident - 04-30-2013 The on or off command must correspond to the feedback status that you specify Ie if status is output then your on and off command must be controlling the same output - agenor - 04-30-2013 Yes, i have done that. For example, the current On and Off commands are controlling Output 6 (a relay is connected to output 6 so i can see it turn on and off). I selected Feedback Type Output and Feedback Name Output 6. Only when i kill the iPAD app and restart it, the real status is shown. - hendy - 05-02-2013 The A1v5.cclx file that you sent to support indicates that the Comfort firmware you are using is the older ULT 6.028. Also the Comfigurator software is of version 3.4.4. Please upgrade both the Comfigurator software and ULT firmware to the latest version. In the newer Comfigurator software v3.6.4 and above there are many new improvements and features, including \"Check for Firmware Updates\" function that check if there is new firmware release available from our website. Please see: http://www.comfortforums.com/forum20/3261.html I do encounter status updating issue in ULT 6.028; but not in the latest firmware ULT 7.027. So please upgrade and let us know the result. - agenor - 05-02-2013 I have upgraded the Comfort controller firmware to 7.027 version and installed the new Comfigurator SW (3.6.8). I have created a test project. With the Home Control menu i am turning the output 6 On and Off. The feedback parameters are as follows: Feedback type = Output Feedback Name = Output 6 The status of the output 6 is not shown, instead only a waiting symbol is shown, i.e. a clock with the text \"waiting\" beside it. Am i missing something? I also tried the F-2 function on the keypad and it works fine, the keypad announces the correct current state of the output 6. - hendy - 05-03-2013 Hmm... Perhaps the UCM/ETH02 firmware? Please upgrade to the latest version as well. - agenor - 05-03-2013 Yes, the firmware upgrade fixed the problem. It works fine now. Thank you for your help! |
