Who Installed Comfort? - Printable Version
+--- Thread: Who Installed Comfort? (/thread-3121.html)
Pages: 1 2 3
- Wimphot - 01-20-2014
I self in installed Comfort maybe 12+ years ago, using it to replace a Modern Alarms system which I discovered I had been paying for Redcare monitoring on (for 6 years!) but it was never properly connected! Bought a new system when I moved 6 years ago and self installed again. Would do it a third time (or get it done for me).
My minor gripes are:
1/. I find the manuals a bit of a nightmare.
and
2/. I cannot program with a Mac (although I think this may have changed - I have a UCM/Eth which I bought some time back but have not gotten around to installing - I believe I can use this with a web interface - so must explore in more detail.
- Stub - 01-20-2014
[user=4835]Wimphot[/user] wrote:
Quote:2/. I cannot program with a Mac (although I think this may have changed - I have a UCM/Eth which I bought some time back but have not gotten around to installing - I believe I can use this with a web interface - so must explore in more detail.
Haven\'t tried a web interface, but yeah, I have to boot-up Windows8 under Parallels to solve that lack of OSX software problem. That works well to the UCM/Eth and Comfigurator. I do all my firmware upgrades that way too.
\"Haven\'t tried a web interface, but yeah,...\"
Is here a web interface? or more accurately browser based interface?
(the answer, I know, can be found by trawling thru the forum so I am being a bit lazy I know!)
- Stub - 01-20-2014
Sorry, no idea. Haven\'t needed to look for it TBH!
I\'d better stop being lazy then Wink
- raygregg114 - 01-21-2014
Just a great product, easy to install and if you have issues there is always help on the other end of your internet connection. I installed this myself and everything simply went together. Small issues with firmware upgrades were sorted in less than an hour. Where would you go or what would you have to pay for this type of service.
- ident - 01-21-2014
Quote:\"Haven\'t tried a web interface, but yeah,...\" Is here a web interface? or more accurately browser based interface?
The UCM/ETH02 is a serial to ethernet converter and is not able to support a browser interface.
The later UCM/ETH03 can support a webserver so it may be able to implement a browser interface in future
- Swiss-Toni - 07-18-2014
I started by installing one of these for myself to learn how to install home automation systems and through trial and error using the forums and with the support from Cytech team I have now installed 3 of these systems proficiently. However I consider myself to always be on a learning curve with this equipment as I constantly update adding commands and components.
- Home - 07-24-2014
Philbo
Unfortunately we are based in the south - if we are passing or you are prepared to pay for over night we would welcome the chance to commission the installaton.
- Daylehouse - 09-21-2014
I installed Comfort myself, I had Comfort 1 before Comfigurator and you had to program with CCX (I think it was called) and pay for a software licence. The addition of more UCMs with added functionality has been great. I started with X10 but now run CBUS for power control, Crestron for A/V / multi-room audio and of course Comfort for security.
I find myself using Comfort for a lot of automation logic mainly because its simple to program and solid for reliability. All of the house sub systems can communicate, I use Comfort as a \"gateway\" between the Crestron and C-Bus system. I avoid using PC based servers, used Homeseer years ago but found PC to less reliable. I have a rain sensor hooked up to Comfort to water my garden by triggering a pump in a water butt, last thing I need is a over-watered garden because the PC failed, so Comfort does this job just great.
Looking forward to see what is next for Comfort, nothing on the market quite like it!
