Comfort Upgrade - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: Questions on Using Comfort (https://www.comfortforums.com/forum-159.html) +--- Thread: Comfort Upgrade (/thread-2695.html) Pages:
1
- ident - 02-18-2012 Yes there are extra mounting positions in the enclsoure for UCM size modules which include LEms, RIOs and DM02 4 metal pillars on top of Comfort II PCB may be for an LEM They are not there by default so someone must have screwed them in - Home - 02-18-2012 IF you do not have the original file then - I personally would upload the old file for reference ONLY. - Use a suitable blank template (I can provide one) and build a new file up from scratch. In my experience the upload procedure is never 100% guaranteed to provide the results that you may desire.... this comment is based on years of experience.. Hope this helps - ident - 02-18-2012 Quote:In my experience the upload procedure is never 100% guaranteed to provide the results that you may desire.... this comment is based on years of experience..Thats true Hpwever, the Upload (now called \"Read from Comfort\") has been improving over the years and now is much better than before Select the option \"Autogenerate Names from Responses\" instead of \"Keep Names from Configuration\" so that Response Names can be generated from Action codes to give the Responses from Comfort some meaning. Response names are not kept in Comfort - Guest - 03-13-2012 I now have the ACC-PLATE01 but not sure how to mount the new comfort board on it. I presume the plate is screwed to the existing pillars in the enclosure but how does the board attach to the plate? Presumably I need some spacers or pillars. - ident - 03-14-2012 The mounting of the Comfort II PCB onto the ACC-PLATE01 is shown below The 8 plastic standoffs allow the PCB to mount onto the ACC-PLATE01. These standoffs are included in the AP01 pack which is part of the CM9000 or upgrade product ![]() The outer mounting holes on the ACC-PLATE01 allow the whole plate to be mounted on the old metal enclosure. The screws used to secure the old Comfort I PCB onto the enclosure can be removed and used for AC-PLATE01 - Guest - 03-14-2012 Thank you - that makes it very clear. Perhaps these instructions could be included on the ACC-PLATE01 page of your website. - ident - 03-15-2012 yes good idea see https://www.cytech.biz/product_details.php?item_id=1 |
