Send Commands via TCP/IP - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Support (https://www.comfortforums.com/forum-2.html) +--- Forum: Comments, Suggestions & Feedback (https://www.comfortforums.com/forum-22.html) +---- Forum: Wishlist (https://www.comfortforums.com/forum-66.html) +---- Thread: Send Commands via TCP/IP (/thread-2646.html) Pages:
1
- Pgordon - 11-23-2014 SONOS has never, and currently does not support static IP address assignment, and I\'m not aware of any intention to change that. However, it\'s really not a problem, as you can certainly pseudo-fix it to a single IP address with a DHCP reservation in your router... - SONOS only supports DHCP, so if you have SONOS working, you must have a router or some other device acting as a DHCP server... set reservations for the SONOS MAC addresses to the single IP you wish to assign each zoneplayer, and viola... - mattbrain - 02-16-2017 SolidCactus wrote: Quote:Hi, I don\'t know whether you are aware of this - http://www.comfortforums.com/forum136/ - but it should do everything you need. Thanks, Matt |
