Reading values back from Comfort - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Third Party (interfacing to Comfort) (https://www.comfortforums.com/forum-5.html) +--- Forum: KNX (EIB) (https://www.comfortforums.com/forum-12.html) +--- Thread: Reading values back from Comfort (/thread-2239.html) Pages:
1
- ident - 04-20-2011 Yes you can do If Security Mode = Off then Reset System Endif If the system is reset while the security is armed, after reset it will re-arm to the same security mode - TheMax74 - 11-02-2011 Hello, i\'m interested too in reading comfort zones from Gira homeserver or any other external device. Maybe you can implement a simple way to re-send all mapped zones (like when you reset comfort) by reserving a mapped group address to do it. - ident - 11-02-2011 Perhaps there is a way to send a message to reset the UCM/KNX so it can resend the zones - ekarak - 05-23-2012 Hello good people at Cytech! Regarding the alarm & zone status updates to the KNX bus: it is essential that the UCM/KNX responds to status reads. I\'ve noticed in large installations (>16 zones) that packet drops are possible, thus you cannot be certain if a zone is open or not (so as to show it on a KNX touchpanel). UCM/KNX has to be more frugal regarding the sending of bursts of packets on the KNX bus. Thus, if a KNX screen displays all zones on a floor it could query the bus for the zone status. Responding to KNX READ request packets shouldn\'t be too hard to implement (if UCM/KNX has its own CPU and memory, why not?). - ident - 05-23-2012 Perhaps it may be possible for the UCM/KNX to respond to read requests from the Bus However in your example if a KNX screen shows many zones and you query each zone for its status then that is going to cause a lot of traffic on the bus which itself may cause more problems Our understanding is that KNX has a mechanism to do error correction so should not drop packets to cause zones status to be incorrect? - ekarak - 05-23-2012 The KNX standard states: no more than 3 retransmissions for a failed transmit with random back-off delay (not exponential like Ethernet!), so: Yes it\'s possible for a poorly programmed device that floods the bus to saturate it. That\'s the reason why in practice most KNX devices have a \"maximum transmissions rate\" parameter, typical value set to something like 30 packets / 15 sec., as well as a \"wait timeout before reading initial values from the bus\" so as touchscreens coming alive after power failure to wait a little before querying e.g. temperature sensors. |
