UCM/Ethernet - old hardware - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: UCMs (https://www.comfortforums.com/forum-146.html) +---- Forum: Ethernet UCM/ETH03 (https://www.comfortforums.com/forum-113.html) +---- Forum: UCM/ETH01 & UCM/ETH02 (https://www.comfortforums.com/forum-119.html) +----- Thread: UCM/Ethernet - old hardware (/thread-1763.html) Pages:
1
- jtankard - 02-25-2010 Tried this, I had wireless and ethernet, disabled wireless and same result, there is activity on the module when the ethernet x over is inserted. DS Manager is V5.7.7 - hendy - 02-25-2010 [user=3236]jtankard[/user] wrote: Quote:Hi I have a Comfort Ultra purchsed a few years ago and only just being put into use.I\'m confused here. First, you are saying D103 is flashing twice every few seconds and then again, D103 is on most of the time??? Which one is which? [user=3236]jtankard[/user] wrote: Quote:I am using vista in both computers i have but i downloaded the latest version and that does not see the device.Second, which LED you are referring to as double flash and triple flash? [user=3236]jtankard[/user] wrote: Quote:I have got the same result, when I plug the x over lead in I see a flurry of activity on the activity LED but DS manager still does not see the device.Third, activity LED you are referring here is D101, D102, D103 or D104? Lastly, if you have another cross-over cable please try with it and see if it of the same result? - jtankard - 02-25-2010 Sorry its D102 on most of the time and flashes when ethernet cable is inserted D103 gives the double flash (never seen the tripple flash) other led\'s are out. Tried two x overs and 2 patch leads (when using the switch) - Ingo - 02-25-2010 It\'s not about IP addressing, the DS Manager sends out a broadcast packet and the UCM then replies to that. I just tested it with a completely bogus IP and it still picks up my unit. Try installing the latest, mine is 5.7.10(x64) and I installed only the Core files, not the monitor and all the other stuff. Both on XP and Windows 7 it works fine but I must confess, it never used to work well on Windows 7 until recently. Don\'t ask me what I did because I don\'t know... It could be a patch on the OS side or something. Also check your LAN card binding order just in case. http://www.windows7news.com/forum/general-windows-7-help/how-do-i-change-the-network-binding-order-in-windows-7/ Ingo - slychiu - 02-26-2010 The latest DS Manager is 5.7.11, available from http://tibbo.com/downloads/soi/tdst.html Make sure you select the correct version, x86 or x64 if you have a 64 bit processor Let us know if that fixes the problem Also you should have SP2 if you are using Vista - slychiu - 03-12-2010 Hi Jtankard, did the new DS Manager resolve the problem? - jtankard - 03-12-2010 No. I got a new serial UCM and used that, I also tried putting the Tibbo module on then new UCM (selecting 485) and that did not work either. I am ok as i can now set the system up on rs232, I cannot fifure out why the ethernet does not work unless the Tibbo module is faulty. - slychiu - 03-12-2010 Would you like to return the UCM/Ethernet for testing? Also note that we have UCM/USB as well as UCM/232 - jtankard - 03-12-2010 If you dont mind,. I would be intrested to see what was up with it, or if its something i am doing wrong, its never been used although its a few years old. I have also updated the firmware on the comfort unit as well and I still have the same result. |
