Door station calls to mobile phone - Printable Version +- Comfort Automation/ Security System Forums (https://www.comfortforums.com) +-- Forum: Products (https://www.comfortforums.com/forum-3.html) +--- Forum: Questions on Using Comfort (https://www.comfortforums.com/forum-159.html) +--- Thread: Door station calls to mobile phone (/thread-1131.html) Pages:
1
- admin - 11-26-2008 Action 199 was implemented from Action 4.233 onwards This is documented in the Action Codes Manual downloadable from www.cytech.biz/manuals.html If you have Comfort I Pro 4.22 (not 4.220) it should be have been built in 1998.! - johnathan_dooley - 11-26-2008 The firmware I have is v4.222 (4.22 was a typo) I want Comfort to announce when an event has happened such as \"Heater On\" If I do not upgrade to 4.233, then it appears the only way i can do this is to record and play back a reminder message, when the event occurs. Can you confirm? Thanks - admin - 11-27-2008 Yes you can use the action Play Reminder Message N on keypads/door stations triggered by any event You record a reminder message 1 to 8 on the keypad or telephone - telephone in preffered for lower noise - roytheboy25 - 02-02-2010 I have firmware version 4.234 and cannot get action 199 to work either. Any suggestions what may be the problem. - slychiu - 02-03-2010 We gave determined that Action 199 (Say Words) does not work in Comfort I 4.234 or any Comfort I firmware. You need Comfort II for this action - Ghyllwood - 05-03-2010 I have a Fermax intercom on the gate and also at the front door. I have integrated this with 2 X DM01 interfaces. Now ever since I have had this installed I cannot get the volume right and I can hardly hear the caller on my mobile phone. The level is not too bad on the house phone and similar to that of the Fermax handset. Are the adjustments I can make to get the Fermax intercom louder on my mobile? The Menu and answer phone level is fine over the mobile. If I changed to DMO2 interfaces for the Fermax, is this going to improve anything? Any thoughts on this greatly appreciated. Thanks Graham - admin - 05-03-2010 We need to know what Comfort firmware you have, Comfort I or Comfort II, and what firmware versions If Comfort II you should upgrade to the latest firmware currently 5.183, see http://www.comfortforums.com/forum79/1784.html for download link and history Also upgrade to the latest Comfigurator 3.1.9 and do a selective write of Tuning parameters to the system This should give good audio levels for the Intercom Lets close this topic and start a new topic in the \"Problems and Troibleshooting\" forum at http://www.comfortforums.com/forum36/ devoted to your question rather than adding to the end of this post which is not related, to do with how to dial out for door station |
