Virtual inputs
 Posted: Monday Aug 30th, 2021 12:59 pm
theshepherdmatt
Hi guys,
I cannot remove the virtual inputs on 2 of my zones?
any help will be appreciated.
cheers
matt
Attachment: Capture.PNG (Downloaded 28 times)
 Posted: Monday Aug 30th, 2021 02:16 pm
Do you know how they became virtual? Virtual inputs are created by making to Knx, cbus, modbus etcIf you remove the Mapping the virtual input should no longer be virtual
 Posted: Monday Aug 30th, 2021 03:23 pm
theshepherdmatt
I have a few mqtt sonoff PIR sensors that I have connected. When I try to create a new virtual response the only zone option I can select is 1 & 2, the only way I could create a virtual response is to manually edit the Action codes which I know nothing about.
The code I used was 154,17,1, 255
This allowed me to create a virtual input to zone 17
Attachment: cinema.PNG (Downloaded 26 times)
 Posted: Tuesday Aug 31st, 2021 01:36 am
Comfigurator does not allow you to make a zone virtual. You are not allowed to directly change the zone to Virtual in the Zone Settings as that would probably cause a lot of problems.
The only way to remove the Virtual Setting now that you have edited the Action Code is to edit the cclx file manually using a text editor.
eg
    <Zone Number="1" Name="Z01-Start_Stop" ZoneTypeName="SwitchNO" EntryPath="true" Restore="false" Partition="0" Eol="NoEol" VirtualInput="true" Announce="false" OnResponseName="TurnON" OffResponseName="TurnOFF" />
Change Virtual Input="false" for the zone. Make sure you backup a cpioy of yhe cclx file before you attempt this
 Posted: Tuesday Aug 31st, 2021 09:44 pm
theshepherdmatt
Ahhh gotcha, that did the trick
thanks
 Current time is 06:36 pm
