not getting the counter value I am expecting
 Moderated by: slychiu Page:    1  2  Next Page Last Page
 Posted: Friday Oct 28th, 2016 10:07 pm
wexfordman
Still sruggling with getting my heating working corretly, and I think the problem is down to counters and adding etc.
Here is my response
Get counter 91
get negative
add living_stback_tmp
set living_stback_tmp
Get counter living_dset_temp
Set living_stback_temp
get counter heat_hyst
Get negative
Set heat_livingdelta
Do heat living allign
Before I execute, my counter value are as follows
counter 91 = 22
living_stback_tmp =100
living_dset_temp=25
heat_hyst= 2
After running, my values are
counter 91 = 2
living_stback_tmp =280
living_dset_temp=25
heat_hyst = 2
livingdelta = 65535
Can anyone explain this, as these are not the results I would expect at all!
 Posted: Friday Oct 28th, 2016 10:17 pm
Please post the response in a code tags. What value do you get and what do you expect?
 Posted: Friday Oct 28th, 2016 10:20 pm
wexfordman
have them listed in the post (format cooming out all messed up, sorry)
 counter 91 =22
livingstback_tmp=280
livingdelta =65535
 Posted: Friday Oct 28th, 2016 10:21 pm
wexfordman
sorry ingo, what do you mean code tags ?
 Posted: Friday Oct 28th, 2016 10:24 pm
When you post you can wrap the text in tags. See one of the options when pressing 'reply' - NOT 'quick reply'.
 Posted: Friday Oct 28th, 2016 10:34 pm
wexfordman
sorry, done now :)
 Posted: Friday Oct 28th, 2016 11:08 pm
Should the answer be '101'?
 Posted: Friday Oct 28th, 2016 11:16 pm
wexfordman
Ingo wrote: Should the answer be '101'?
living_stback_temp should b 103, but is 280
living_delta should be 101 but is 95535
 Posted: Friday Oct 28th, 2016 11:30 pm
I'll let Cytech take a look. I think it has to do with High|Low bytes especially the very first -22 which is returned in two steps. First one by LastActionValue and next by using Action Code 38.
 Posted: Friday Oct 28th, 2016 11:43 pm
wexfordman
thanks Ingo
 Posted: Saturday Oct 29th, 2016 05:06 pm
I did a quick test on your code and found that at the point shown below the results do not appear to be correct as per the documentation. Perhaps I am missing something but adding immediate '78' works but adding a counter with value '78' doesn't.
get counter 91
get negative
add living_stback_tmp <-- Here the result is not as expected.
Get negativeadd living_stback_tmp
 Posted: Sunday Oct 30th, 2016 12:13 am
wexfordman
Thanks again ingo,
Cytech, can you help with this one?
 Posted: Sunday Oct 30th, 2016 06:06 am
13th Post
tech07
Is this what you expect and not getting?
get counter 91 (= 22)
get negative   ( -22)
add living_stback_tmp (+ 100 = 78)
set living_stback_tmp ( 78)
Get counter living_dset_temp (25 )
add living_stback_tmp (+78 = 103)
Set living_stback_temp (103)
get counter heat_hyst (2)
Get negative (-2)
add living_stback_tmp (+103 = 101)
Set heat_livingdelta (101)
counter 91 is not changed by the code but you say it becomes 2 so there may be other responses changing it
For testing can you send the cclx file to support@cytech.biz as it will be easier to simulate with the actual code
 Posted: Sunday Oct 30th, 2016 03:23 pm
14th Post
wexfordman
tech07 wrote: Is this what you expect and not getting?
get negative   ( -22)
Get counter living_dset_temp (25 )add living_stback_tmp (+78 = 103)Set living_stback_temp (103)get counter heat_hyst (2)Get negative (-2)add living_stback_tmp (+103 = 101)Set heat_livingdelta (101)
Thats the problem alright, I am not getting the correct value in either living_stbck_temp or in heat_livingdelta
I have emailed my file, thanks.
Regards,Eamon
 Posted: Monday Oct 31st, 2016 05:52 pm
15th Post
There seems to be something wrong. we are investigating
 Posted: Monday Oct 31st, 2016 05:54 pm
16th Post
wexfordman
slychiu wrote: There seems to be something wrong. we are investigating
Thanks slychiu, been doingng my head in the last few weeks, was convinced I had it wrong.
 Posted: Tuesday Nov 1st, 2016 08:41 am
17th Post
We have found a bug with add counter and add sensor actions and will get a new version with the fix soon
Thanks for the information
 Posted: Tuesday Nov 1st, 2016 01:22 pm
18th Post
wexfordman
Brilliant thats slychiu.
How long do you think before a fix ? Winter encroaches, and I need this to get my scs thermostat controlled heating working
Regards,Eamon
 Posted: Wednesday Nov 2nd, 2016 04:46 pm
19th Post
ULT 7.115 Beta can be diwnloaded from http://www.cytech.biz/product_details.php?item_id=210 to fix this problem
Please test and let me know that it fixes this problem for you
 Posted: Wednesday Nov 2nd, 2016 05:13 pm
20th Post
wexfordman
Thanks slychiu, I will have a look this evening after work, thanks for quick response
 Current time is 06:42 pmPage:    1  2  Next Page Last Page
