Missing action codes
 Rating:  Rating
 Posted: Wednesday Apr 22nd, 2015 06:18 pm
mikeinnc
I notice that the Action Codes Reference manual doesn't appear to have all the codes that are currently available in Comfigurator and presumably the later firmware. For example, the task 'wait 2 seconds using timer 25' codes as 190,25,0,2. Yet I cannot find the "190" code anywhere in the manual. So now I wonder - how many other codes have been introduced since the manual was last updated? Is here a list somewhere of ALL codes? It looks like the Reference manual is over 2 years old. Is an update on the cards?
 Posted: Thursday Apr 23rd, 2015 08:15 am
It has not been updated for some time
The updated action codes reference is now available from http://www.cytech.biz/product_details.php?item_id=147
 Posted: Thursday Apr 23rd, 2015 08:45 am
mikeinnc
That's excellent! Thanks very much.
 Posted: Thursday Apr 23rd, 2015 12:06 pm
mikeinnc
OK, now I have the new codes, can you please explain why I cannot branch 'backwards'? I want to set a counter; perform an action; decrement the counter and if it isn't zero loop back to the action (again). Firstly, there appears to be no 'Comfigurator' programming codes to allow this, and if I try to set it manually, using, for example "Edit Action Codes" and codes 115, 231 as soon as I hit OK (or Apply) the negative offset 231 gets set to 0 and the code is totally screwed up! Comments or suggestions welcome!
 Posted: Thursday Apr 23rd, 2015 04:36 pm
according to the action codes spec you should be able to branch back. Nobody seems to have tried this before. We will investigate
 Posted: Thursday Apr 23rd, 2015 06:23 pm
mikeinnc
Thanks so much. I believe I may have found another error. I have an X10 'Bedside / Desktop Timer Controller' and I have programmed the X10 A4 Off response so that it also turns off the bedroom (CBus) lights. It saves getting out of bed! It works very well - if room lights are on and the '4 Off' button is pressed on the Controller, both bedside light and room lights switch off. Exactly as expected. However, I also applied the same response to the X10 'A All Off' response - and not only does it not work, but pressing the controller 'All On' button (incorrectly) turns OFF the room lights, and (correctly) turns ON the X10 A4 light! So now I have swapped the room lights response on the X10 response page to the X10 'A All On' response (and made the 'A All Off' a null response) - and it works! So it appears that something has swapped the 'All On' code with the 'All Off' code. I can live with it - it works! - but it it is an inconsistency that needs investigation? Thanks.
 Posted: Friday Apr 24th, 2015 01:25 pm
mikeinnc
Although I haven't tried every one, it looks as though NONE of the 'branch' codes will accept a negative offset. Attempting to manually set codes produces strange responses when you hit 'OK'. Branch codes change; text that isn't referenced anywhere appears - for example, "Branch 5" and the offsets change to zero. Apart from this, of course, there is no coding ability within Comfigurator to allow negative offsets. I find it difficult to believe that such a common programming construct that is clearly referenced in so many places in the Action Codes manual just doesn't work. Even a very simple three or four line "response" - set a counter with a non-zero value, decrement and branch back to the decrement instruction if not zero - just does not code nor work. :(
 Posted: Friday Apr 24th, 2015 05:42 pm
Branch negative is possible in the action codes. However the problem is Comfigurator does not have a suitable construct to handle this
If Then Else statements are supported which uses the positive branch actions
Branch negative requires Do While or For /Next in Comfigurator, otherwise even if you enter the action codes manualy, comfigurator does not know how to encode it.
This type of statement should be added in future but we need to study more
Does anyone else think this may be a good feature?
 Posted: Saturday Apr 25th, 2015 03:47 am
mikeinnc
Well, as I raised the issue, I think the programming ability of Comfort loses a great deal of flexibility by NOT having this structure. This is especially true as clearly the underlying code supports it! So having For - Next or While - Wend looping (or both!) would appear to me to be essential!
As an aside, is there any way the codes can be programmed without Comfigurator?
 Posted: Saturday Apr 25th, 2015 06:02 am
You can enter action codes from the keypad by Engineer Menu Press F0 and engineer code (6789# by default)To to menu 3,6Enter Response Number and # keyenter the action codes terminated by 255
Refer to Engineer Programming Manualhttp://www.cytech.biz/engineer_menu_programming_manual.html
However if you write by Comfigurator it will write over itRead from Comfigurator will also not understand the actions
 Posted: Wednesday Apr 29th, 2015 05:15 am
mikeinnc
Referring to my previous post, it looks like probably all the X10 'All On' and 'All Off' codes are swapped. I have changed my X10 light from house-code A4 to C3 and changed all the response codes accordingly. However, I still need to use the C 'All On' response to turn the lights off! :(
I realise that X10 isn't flavour of the month, but where it exists, it can still be useful as I am proving. Can this anomaly be investigated, please? I would assume it could be corrected in a future firmware update?
 Posted: Wednesday Apr 29th, 2015 09:16 am
Thanks, We have confirmed the bug in X110 Received Responses for All On and All off codes
This has been posted to the X10 forum for easy reference http://www.comfortforums.com/view_topic.php?id=4194&forum_id=33
 Posted: Thursday Apr 30th, 2015 05:13 am
13th Post
mikeinnc
Thanks for confirmation. I'll look forward to the firmware update.
 Posted: Thursday Apr 30th, 2015 05:34 pm
14th Post
eborges
I thik it would be a good addition to Comfigurator the possibility of using  Do While or For /Next constructs.
 They are a basic feature that can be found in any programing language.
I would certainly make use of them.
 Posted: Thursday Apr 30th, 2015 05:45 pm
15th Post
Please check out ULT 7074 beta http://www.comfortforums.com/forum33/4194.html which fixes the x10 all on/off received response
 Posted: Friday May 1st, 2015 05:31 am
16th Post
mikeinnc
Well, of course, I entirely agree with you! I find it amazing that a 'programmable' system that has the 'microcode' ability to support this construct doesn't have it at the 'higher language' level. Let's hope we get some more support from others to get this adopted.
Meanwhile, I have worked out a way to do this using 3 responses. In my specific case, I want to flash some lights three times. I have three responses which we will call Response1; Response2 and Response3.
Response1:
If NightTime <> 0 Then    If Counter Counter013 <> 0 Then !CBus Grp 13         Set Counter051 = 3        Do Response2    End If  End If
Response2:
Cbus2 UCM02 13 25 121  Wait 3 Seconds Using Timer25  Cbus2 UCM02 13 25 1  Wait 3 Seconds Using Timer25  Decrement Counter051  Do Response3
Response3:
If Counter Counter051 <> 0 Then Do Response2   End If
It works - but it is "messy" and we shouldn't have to go to this level!
 Current time is 07:54 am
