Need help on setting counter value
 Posted: Friday Feb 28th, 2014 04:43 pm
evard
Hello expert,
I want to set KNX control in iphone Application (Switch On/Off light).Can you please give me some guide on this?
I have mapped 3 knx address (1-bit switching) to counter as below:
0/1/0 (Light 1) -> Counter000
0/1/1 (Light 2)  -> Counter001
0/1/2 (Light 3)  -> Counter002
Responses:
========SwitchOff: -----------
If  LastUcmCounter= 0
 Then  Set LastUcmCounter = 255
End If
SwitchOn: -----------
If  LastUcmCounter=255 Then
  Set LastUcmCounter = 0
End If
Control Menu==========
Control Group 0-
0- Room 1 (Feedback: Counter 000)
   0- Off (Response: SwitchOff)
   1- On (Response: SwitchOn)
1- Room 2 (Feedback: Counter 001)
2- Room 3 (Feedback: Counter 002)
Counters=======
0 Counter000 NullResponse
1 Counter001 NullResponse
2 Counter001 NullResponse
When I try to execute response, I did not get the expected result.
 Posted: Friday Feb 28th, 2014 05:55 pm
The way you have programmed it, you will not be able to control the KNX lights from your control menu.
"If Last UCM Counter " should be used only in a Counter Response, NOT in a response sending commands to KNX. "If Last UCM Counter" is used for KNX to control Comfort not for Comfort controling KNX
The On Response should be eg
 KNX 0/1/0 On
Off Response should be eg
KNX 0/1/1 Off
Use the Response Wizard to program the KNX Commands
This is explained in detail in the UCM/KNX Manual which canbe downloaded from http://www.cytech.biz/ucmknx_manual.html?category_id=107
 Posted: Monday Mar 3rd, 2014 04:49 am
evard
Hi ident,
Thanks for the help and I got it working now.
 Current time is 06:33 pm
