Sign in code Response
 Posted: Monday Apr 26th, 2010 01:39 pm
jasontodhunter
Is it possible to make a certain sign in code carry out a response.
I would like to login remotely with a code to open a gate but don't want to go through the home control menus.  Can a certain sign in code trigger a response purely by signing in.  This sign in would obviously only be used for this purpose.
 Posted: Tuesday Apr 27th, 2010 05:34 am
You cannot activate a Response just by signing in
The way you want to do it is problematic even if it could be done, because if  you could enter a code to open the gate remotely, the code could be entered locally on a keypad and thus would also open the gate. It could be explained to the user but nevertheless it may be a problem.
A better alternative is to use a UCM/GSM. This allows you to send a text message from a programmed phone number to open the gate
 Current time is 08:49 am
