Engineer test mode On = "Invalid" responce
 Posted: Thursday Oct 25th, 2018 10:59 am
norrisp90
I cannot enable engineer test mode. I enable the engineer sing in option, sign in as engineer, then try to enable engineer test mode and every-time I try and switch it on the response is "Invalid". Any ideas why?
It's an Ultra II with latest firmware.
Thanks.
 Posted: Thursday Oct 25th, 2018 12:17 pm
Engineer Test Mode is only valid if the system is Disarmed. if armed, it will say Invalid when you try to enable it
 Posted: Tuesday Oct 30th, 2018 12:09 pm
norrisp90
The system is always disarmed when I try. It still gives me response "invalid".
 Posted: Tuesday Oct 30th, 2018 01:49 pm
You are pressing 8, 6, 1 in Engineer Mode to enable engineer test mode?
If the system is not in alarm or armed it should work
Read the event log and send it and the cclx file to support@cytech.biz for testing
alternately you could use Test mode, F3,1 which is almost the same as Ebgineer Test Mode
 Current time is 06:35 pm
