Comfigurator 2.2.0 Released
 Posted: Sunday Jul 1st, 2007 02:21 am
The new version of Comfigurator 2.2.0 has been released. Please download from http://www.cytech-technology.com/temp/software/Comfigurator2.2.0_Single.zip
Please note that Engineer Code is required for download and upload. First, press F0 to enable Engineer code
The default Engineer Code is 6789
NOTE: PLEASE DOWNLOAD DEF31.CCT TEMPLATE FOR COMFORT II OPTIMUM (See attachment) AND REPLACE THE ONE INSTALLED BY COMFIGURATOR 2.2.0
Please review Known Issues below
HISTORY
V2.2.0 15/06/2007
Bug fixes
  • Fix problem with response compilation if response number = 255
  • Fix problem with erroneous values in event log listing
  • Save CCL values using English locale to avoid problem with comma as decimal point in Siren duration
  • Limit counter value in IF statement to 254 to avoid erroneous end of response detection
  • Fix incorrect values set for reminder message destinations
  • Support user-entered branch actions
  • Fix exception on incorrect user-entered action codes
New features
  • Hide ringer details for Comfort II
  • Remove licensing checks
  • Remove alpha pager
  • Require engineer code for up/download. Press F0 on keypad to authorise
  • Disable UCM concatenate if not CBUS
  • Launch WizComfort
  • Edit zones, zone types and alarm types using popup dialogs
  • Right-click on zone type in zone popup to display/edit zone type
  • Add descriptions and enable editing of tuning parameters for Comfort II
  • Associate names with X10 transmitted codes (referenced within responses)
  • Support UCM type Rako
  • Support UCM type Lutron
  • Support UCM as target for reminder messages
  • Display some actions in more than one category in Response Wizard
  • Support Sunrise/Sunset times
  • Support firmware download
  • Support unknown action codes
  • Allow either IP address or hostname for network connection
Known Issues
  • Zone Types Screen sets Night Mode Settings to "Perimeter" and Sensitivity to 10
  • Response Wizard - when sorted by Name, after adding a new Response, goes back to sort by Number
  • Unable to save file with sensor register as feedback type.
  • Saving file with a sensor register and then re-opening the file doesn't display the response.
  • Program Crashes when double clicking on the right side of certain screens which have no fields eg Zones and Zone Types
  • def31.cct installed by this program should be replaced by the new file def31.cct in the attachment to this post
  • In Security > CMS, if the Account Code is less than 6 digits, the leading digits 00 are added. eg 4567 becomes 004567. Change using the keypad Engineer Menu 4 for Phone Numbers, select Phone 1 or 2 , 1 for Type CMS, 1 for Monitoring Station Code and enter the account code and # key, eg 4567#. This bug was from Comfigurator 2
Attachment: def31.cct (Downloaded 15 times)
 Current time is 04:54 pm
